Drag to folder on network drive
Re: Drag to folder on network drive
Can you tell us more about the problem? Is the network drive mapped or not? What version of Windows? What version of WinSCP? Installed or portable or downloaded from Microsoft Store?
Sondr
Hello!
Yes, the drive is mapped (This PC -> Map network drive), but the problem is also actual for any network path.
Windows 10 Pro 1803.
WinSCP 5.14.1 beta (Build 8909), portable, i downloaded it from this site.
If you open that mapped drive in Windows Explorer and create a file on the drive somehow (e.g. saving a new file from Notepad), does the Explorer window show the file automatically (without manual refresh)?
Go to SSH > Authentication page of Advanced Site Settings dialog:
https://winscp.net/eng/docs/ui_login_authentication
Click Tools > Generate New Key Pair with PuTTYgen. In PuTTYgen, generate a new key and save it to a local drive. WinSCP should detect that and insert a path to the key file to the Private key file box.
Now repeat the same for the mapped network drive. Does it work or not?
