No access to S3 Bucket Folders directly
Guest43434
WinSCP 5.13.2 (Build 8455)
Windows 10 (Version 1709)
Using GUI/Commander
Transer Protocoll S3
It is not possible to access S3 Subfolders within an AWS S3 bucket directly. Configuration of an remote folder works with first level bucket folders only, e.g. "/bucketname". I haven't found a possibility to access subfolders directly (e.g. "/bucketname/folder1"). From my point of view, this feature is required, because I do only have permissions to those subfolder not allowed to see any folder on level "/bucketname". Using the tool S3 browser I have checked my permissions (works!).
Thanks in advance
Re: No access to S3 Bucket Folders directly
Sorry, I do not really understand, what are you trying to do. What configuration are you referring to?
Quest182728
I'm facing the same issue. I only have an access to a certain folder within a bucket and seems that WinScp doesn't support this. Both S3 Browser and CloudBerry explorer are working fine.
