Checking file existence - using mask in file extension
luisa.rodriguez
MX
Hi all,
I'm using the functionality described in the following post: https://winscp.net/eng/docs/script_checking_file_existence
to check if a file exists in an ftp folder. And I'm using a mask to get files with similar characteristics. In particular the command ls.
A part of that, I need to use a mask at extension level, for example if the program checks the existence of a file, the following options should return true:
- filename.test00.txt
- filename.test00.log
- filename.test00.cfg
is there a way to check the extension using a mask? something like
- filename.test00.[txt|log|cfg]
thanks for your help[/url]
Re: Checking file existence - using mask in file extension
You can only use filename.test00.*.
For anything smarter, you better use WinSCP .NET assembly.
luisa.rodriguez
MX
Thanks Martin.
Using '*' would not work for me as there could be more files with the same name but different extension.
I will check the Net assembly.
thanks again,
Luisa
