Invalid access to memory - System::Classes::TComponent::FindComponent
julian@...
WinSCP 5.14
(003961F6) System::Classes::TComponent::FindComponent
(008F9532) C5107_0
(008FB59A) ____ExceptionHandler
(008F8354) __ExceptionHandler
(0008341F) ntdll.dll
(00028B60) TCustomScpExplorerForm::AddSessionColor
(0001F284) TCustomScpExplorerForm::DoTerminalListChanged
(000060AA) TCustomScpExplorerForm::TerminalChanged
(00005F92) TCustomScpExplorerForm::DoSetTerminal
(00005F42) TCustomScpExplorerForm::SetTerminal
(00049ACA) TScpCommanderForm::~TScpCommanderForm
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
(0006507B) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00065048) ntdll.dll.RtlGetAppContainerNamedObjectPath
rarnold@...
Dear all, nothing special done: open a session, moving to the target remote directory and local directory; afterwards downloading a WIndows .Net executable file. I would say a typcial standard situation in terms of how to use WinSCP. Regards Ronald
WinSCP 5.14
(008F9532) C5107_0
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
(00137FF0)
(008F9532) C5107_0
(008FA3EB) C5107_0
(008FB3E1) ____ExceptionHandler
(008F94C2) ___doGlobalUnwind
(008FB6AE) ____ExceptionHandler
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
michal@...
Chyba přístupu do paměti - System::Classes::TComponent::FindComponent
Long run WinSCP exception on close. The same as yesterday.
WinSCP 5.14
Chyba přístupu do paměti.
(008F9532) C5107_0
(0007DAFF) ntdll.dll
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
(00062058) ntdll.dll.RtlValidSecurityDescriptor
(00062025) ntdll.dll.RtlValidSecurityDescriptor
jkellgren@...
I was interrupted a couple of times during my session with the external server, but able to rectify by relogging in again. The error below showed up as the point that I close the WinSCP session when I was done.
WinSCP 5.14
(008F9532) C5107_0
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
ahmeda10@...
-Connected to server.
-attempted to close program down.
-Crash.
WinSCP 5.14
(008F9532) C5107_0
(000851DF) ntdll.dll
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
(0006482B) ntdll.dll.RtlGetAppContainerNamedObjectPath
(000647F8) ntdll.dll.RtlGetAppContainerNamedObjectPath
sasho.new@...
It's simple enough. I've just installed this version and crash happens after I closed WinSCP. My PC was "waken-up" not rebooted if this might be important. I'll let you know if crash persists...
WinSCP 5.14
(008F9532) C5107_0
(00051C17) TScpExplorerForm::~TScpExplorerForm
(000F6C03) Execute
(000024FC) wWinMain
(008F7569) C4975_0
Re: Invalid access to memory - System::Classes::TComponent::FindComponent
Thanks for your reports.
https://winscp.net/tracker/1693
I'm sending you an email with a development version of WinSCP to the addresses you have used to register on this forum.
kilian.frey@...
Opening a connection from the shortcut-menu on Windows 10 taskbar when said connection has a background-color causes fatal crash.
Works as expected, if the application is already open.
WinSCP 6.0
(002121AA) System::Classes::TComponent::FindComponent
(00087B7F) ntdll.dll
(0002DCBC) TCustomScpExplorerForm::AddSessionColor
(0002347E) TCustomScpExplorerForm::SessionListChanged
(00030CD3) TCustomScpExplorerForm::SessionsPageControlResize
(003F4F51) Vcl::Controls::TWinControl::WndProc
(003F4598) Vcl::Controls::TWinControl::MainWndProc
(00213A0C) System::Classes::_18201
(00040239) USER32.dll
(000371F5) USER32.dll
(00036DF5) USER32.dll
(0003A9BD) USER32.dll
(00073FBB) ntdll.dll.KiUserCallbackDispatcher
(00034C1A) USER32.dll.SendMessageW
(00421F21) Vcl::Comctrls::TCustomTabControl::TabsChanged
(00423562) Vcl::Comctrls::TPageControl::UpdateTab
(00422A19) Vcl::Comctrls::TTabSheet::CMTextChanged
(003F0048) Vcl::Controls::TControl::Perform
(003EDEA1) Vcl::Controls::TControl::SetTextBuf
(00C8FA4F) TThemeTabSheet::UpdateCaption
(00C8F7C7) TThemeTabSheet::SetBaseCaption
(000236F5) TCustomScpExplorerForm::UpdateNewTabTab
(0002E0C2) TCustomScpExplorerForm::UpdateToolbarDisplayMode
nlgroup@...
WinSCP 6.0
(002121AA)
(00062496) ntdll.dll
(0002DCBC)
(0002347E)
(00030CD3)
(003F4F51)
(003F4598)
(00213A0C)
(000152F7) USER32.dll
(00015D35) USER32.dll
(00015DE8) USER32.dll
(00015E49) USER32.dll
(00421F21)
(00423562)
(00422A19)
(003F4F51)
(003F0048)
(003EDEA1)
(00C8FA4F)
(00C8F7C7)
(000236F5)
(0002E0C2)
@kilian.frey and @nlgroup: Thanks for your reports.
eb@...
WinSCP 6.2.1
(00223F92) System::Classes::TComponent::FindComponent
(00087A7F) ntdll.dll
(0002F328) TCustomScpExplorerForm::AddSessionColor
(00024875) TCustomScpExplorerForm::SessionListChanged
(0000A417) TCustomScpExplorerForm::ConfigurationChanged
(0000AC56) TCustomScpExplorerForm::RestoreParams
(00057B02) TScpCommanderForm::TScpCommanderForm
(003CB762) Vcl::Forms::TApplication::CreateForm
(00D240CB) _SafeFormCreate
(0000318F) wWinMain
(00E1B161) __wstartup
(00066C6C) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00066C39) ntdll.dll.RtlGetAppContainerNamedObjectPath
(00E1D412) C6608_0
(00E1F47A) ____ExceptionHandler
(00E1C234) __ExceptionHandler
(0000318F) wWinMain
@eb: Thanks for your report.
