Batch File for Transfering different file types to different folders
Gerri3d
Austria
I want to use a bacth command to transfer in example *ini, *.com etc files from different source folders to several target folders.
That means I need to select the source directories, file types and target directoris. I found this in the www:
"C:\Program Files (x86)\WinSCP\WinSCP.exe"
/log=c:\path\winscp.log
/command "open sftp://manufact:Sr@xxx.yyy.214.1/"
"put %sourcepath%/*.com %targetpath%/proj/"
"put %sourcepath%/*.ini %targetpath%/cfg/"
"put %sourcepath%/*.txt %targetpath%/lan/"
"exit"
%sourcepath% and %targetpath% are batch variables
BR
Gerri3d
Re: Batch File for Transfering different file types to different folders
I'm not sure if this is a question. And if it is, what the question is.
