Running script in a line rather than having them in cascade
agassparkle
I am very very new to using WinSCP with scripting.
Is it possible to run commands like
rather than
I am generating the file with Excel. That is why I am looking for a way to do it like this.
Re: running script in a line rather than having them in casdcade
@agassparkle: Do I understand right, that you want to run everything form a single (WinSCP) command line?
If that's the case, use /command switch:
https://winscp.net/eng/docs/commandline#scripting
See also
https://winscp.net/eng/docs/commandline#syntax
Also WinSCP GUI can generate a template command-line for you:
https://winscp.net/eng/docs/ui_generateurl
