Include Mask Should Recurse Directories
duerra
Martin,
One of the things that has bugged me a bit is that when using the Include Mask to upload files, it only works in the current directory (unless I've missed something).
It would be nice if WinSCP would either recurse directories when using the include mask by default or accept "//*something.ext*" as an include mask and recurse directories (double slash is xPath lingo for wildcard directory/path selection).
~duerra
_________________
When you put everything into something, it means everything to you.
Re: Include Mask Should Recurse Directories
Please read documentation :-)
The mask */ matches any directory. For example to transfer only HTML files located in any directory, use the include mask */; *.html.
