SSH NEW File creation is different ( Notepad++) as vs direct Edit under NANO
Rar9
Germany
Hello
I created a "config.gateway.json" with some rules that was created with Notepad++ that was not recognised by my Unifi Linux Controller.
I manage to get it fixed by just Cut & Pasting the Same rules into my SSH Nano Editor and the Controller accepts the File.
Is this bug in Winscp transfering via SCP or could it be Notepad++ doing something to the file ?
Re: SSH NEW File creation is different ( Notepad++) as vs direct Edit under NANO
Can you download the file back (in a binary mode) and attach it here, for us to check?
Rar9
Germany
"firewall":{
"name":{
"LAN_IN":{
"default-action":"accept",
"description":"packets from intranet",
"rule":{
"2001":{
"action":"drop",
"description":"Device 1",
"protocol":"all",
"source":{
"mac-address":"xx:xx:xx:xx:xx:x1"
"time":{
"starttime":"21:30:00",
"stoptime":"06:30:00",
"weekdays":"Mon,Tue,Wed,Thu,Sun"
"2002":{
"action":"drop",
"description":"Device 2",
"protocol":"all",
"source":{
"mac-address":"xx:xx:xx:xx:xx:x2"
"time":{
"4001":{
"action":"drop",
"protocol":"all",
"source":{
"time":{
"starttime":"23:00:00",
"weekdays":"Fri,Sat"
"4002":{
"action":"drop",
"protocol":"all",
"source":{
"time":{
max123kl
germany
If you use notepad++ on a windows machine and nano on a Linux machine you may use two different code pages. On windows notepad++ uses ANSI as default. Try to change Encoding/Kodierung to UTF8, which is used by Linux as default. Convert and save the file again.
Anonymous wrote:
??? can't you cut & Paste it as json is not allowed for upload
That won't help. We need to see an exact binary representation of the file.
