Could not authenticate to server: Missing Authentication-Info header Verbinding mislukt.
Wltrng
Utrecht
I just installed WinSCP on a Win 10 machine, using the commander interface.
After setting up a WebDAV connection to OneDrive following the instructions in <invalid hyperlink removed by admin>, I get the message above:
Any suggestions?
Thanks,
Marc
Re: Could not authenticate to server: Missing Authentication-Info header Verbinding mislukt.
pier4r
Just an info
Also to give an update. I tried OneDrive via WebDAV and WinSCP too after the OneDrive website failed me (see https://x.com/Pier4r/status/1276826246391959553) and the WebDAV approach using the file browser failed too.
Two things:
  • if the webgui/filebrowser failed, then restart Windows and then use WinSCP (ONLY WinSCP) Somehow the connection may hang and it hinders WinSCP. You can see in the task manager that the webclient uses the CPU even if everything is closed.
  • remember that in the username you need to put the email domain too. Like pier.example@outlook.com, otherwise it won't work and it says "authentication header missing"
pier4r
Another info
Another update. WinSCP OneDrive WebDAV works, but I found problems with files larger than 100 Mb.
I tried to search the internet and I changed the webclient registry settings, but they aren't related (as the wiki comment about the revert shows, correctly).
Namely:
I have WinSCP 5.17 and Windows 10 Pro, but somehow something is blocking it. I had to either dig deeper in the internet or to try other possible alternatives. I tried Cyberduck with a 114 Mb file and it worked. I don't know what is the difference between Cyberduck and OneDrive (aside from the fact that Cyberduck is a "OneDrive recognized app") but maybe the dev team can look into it to improve things.
Even if nothing happens, it is still great that WinSCP allows WevDAV transfers, albeit up to a certain size. It is a free product so one cannot expect everything.
Re: another info
Thanks for sharing your findings.
I believe that Cyberduck does not use pure WebDAV when talking to OneDrive.
Sacha00Z1
I have the same issue
I tried to follow the same guide, and got the same results. Any advice on how to fix the issue?
2021-12-22 16:45:26.360 Read block (302 bytes):
. 2021-12-22 16:45:26.360 [<html><head><meta http-equiv="REFRESH" content="0; URL=https://login.live.com/XPError.srf?lc=1033&id=281053&ru=https://d.docs.live.net/ZXYABCMNBVC&tw=18000&fs=0&ts=-1&sec=&mspp_shared=1&ec=e2tw&seclog=10"><script type="text/javascript">function OnBack(){}function OnNext(){}</script></head></html>]
. 2021-12-22 16:45:26.360 Running post_send hooks
. 2021-12-22 16:45:26.360 Request ends, status 401 class 4xx, error line:
. 2021-12-22 16:45:26.360 401 Unauthorized
. 2021-12-22 16:45:26.360 Running destroy hooks.
. 2021-12-22 16:45:26.360 Request ends.
. 2021-12-22 16:45:26.360 sess: Destroying session.
. 2021-12-22 16:45:26.360 sess: Closing connection.
. 2021-12-22 16:45:26.360 sess: Connection closed.
. 2021-12-22 16:45:26.360 auth: No challenges accepted.
. 2021-12-22 16:45:26.360 Request ends, status 302 class 3xx, error line:
. 2021-12-22 16:45:26.360 Could not authenticate to server: Missing Authentication-Info header
* 2021-12-22 16:45:26.420 (EFatal) Authentication failed.
* 2021-12-22 16:45:26.421 Could not authenticate to server: Missing Authentication-Info header
* 2021-12-22 16:45:26.421 Connection failed.
  • OneDrive.xml (154 Bytes, Private file)
Re: I have the same issue
@Sacha00Z1: Same in what sense? Do you have problems with uploading files over 100 MB? Or it does not work at all? The OneDrive WebDAV interface has size limitations. Nothing you can do about it.
