How to: Challenge response in PowerShell Script?
El Guapo
United States
I am able to connect to a WebDAV site using WinSCP, and generated the code for that site in PowerShell. However, when I try the code to connect, I get an error saying the Basic challenge is rejected. I've been looking through code examples on the site and also through the forums before asking, but haven't found anything that allows me to handle this from a script. This script is a part of a scheduled automated workflow, so I would need a way to handle this that doesn't require any keyboard input.
Here's the barebones code generated by WinSCP:
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Set up session options
    Protocol = [WinSCP.Protocol]::Webdav
    HostName = "example.com"
    PortNumber = 443
    UserName = "username"
    Password = "password"
    WebdavSecure = $True
try
    # Connect
    # Your code
finally
    $session.Dispose()
When connecting from the Windows app, I looked in the log & saw this:
. 2018-10-04 14:42:00.919 auth: Got challenge (code 401).
. 2018-10-04 14:42:00.919 auth: Got 'Basic' challenge.
. 2018-10-04 14:42:00.919 auth: Trying Basic challenge...
. 2018-10-04 14:42:00.919 auth: Accepted Basic challenge.
When I try my PowerShell script, I get this error:
. 2018-10-04 14:45:59.609 ah_post_send (#1), code is 401 (want 401), WWW-Authenticate is Basic realm="example.com"
. 2018-10-04 14:45:59.609 auth: Got challenge (code 401).
. 2018-10-04 14:45:59.609 auth: Got 'Basic' challenge.
. 2018-10-04 14:45:59.609 auth: Trying Basic challenge...
. 2018-10-04 14:45:59.609 auth: No challenges accepted.
. 2018-10-04 14:45:59.609 sess: Closing connection.
. 2018-10-04 14:45:59.609 sess: Connection closed.
. 2018-10-04 14:45:59.609 Request ends, status 401 class 4xx, error line:
. 2018-10-04 14:45:59.609 Could not authenticate to server: rejected Basic challenge
. 2018-10-04 14:45:59.609 Request ends.
. 2018-10-04 14:45:59.609 Asking user:
. 2018-10-04 14:45:59.609 Error listing directory '/Your Files'. ("Authentication failed.","Could not authenticate to server: rejected Basic challenge")
< 2018-10-04 14:45:59.609 Script: Error listing directory '/Your Files'.
< 2018-10-04 14:45:59.609 Script: Authentication failed.
< 2018-10-04 14:45:59.609 Could not authenticate to server: rejected Basic challenge
. 2018-10-04 14:45:59.609 Script: Failed
> 2018-10-04 14:45:59.796 Script: exit
. 2018-10-04 14:45:59.796 Script: Exit code: 1
. 2018-10-04 14:45:59.796 sess: Destroying session.
Any suggestions would be greatly appreciated. Thanks!
Re: How to: Challenge response in Powershell Script?
Please attach a full session log file showing listing of that directory both from GUI and your code.
El Guapo
United States
Thank you for taking a look at this!
I've anonymized the login & connection info, but otherwise it is unchanged.
Description: Here is the log from my script
Description: Here is the application log
Try to enable password logging with /loglevel=* command-line switch and check if the script is using correct credentials.
El Guapo
How would I do that from a PowerShell script? I copied/pasted the code directly from Session >Generate Session URL/Code. If I can connect via the GUI, why would the credentials be wrong in the generated code?
El Guapo
United States
I decided to use a command line connection as generated by the GUI, formatted like this:
"C:\Program Files (x86)\WinSCP\WinSCP.com" /log="C:\test\test.log" /loglevel=2* /ini=nul /command "open https://username:password@server.com/"
Here's the output I got:
Connecting to host...
Authenticated.
Starting the session...
Session started.
Active session: [1] username@server.com
So there's not a problem connecting to the server & authenticating. It's whenever I try to take an action that I get the basic challenge issue:
winscp> dir
Error listing directory '/'.
I also tried using ls at the winscp prompt and got the same result. Somehow, the WinSCP GUI knows how to handle this, but I'm not finding anything in the documentation that tells me how to handle it.
El Guapo
I didn't choose WebDAV. When I created the connection, WinSCP somehow detected that they were using WebDAV, and that's what is in the generated code from WinSCP. I've already tried changing the protocol and get connection errors. I'm just trying to figure out why the WinSCP GUI can handle the basic challenge, but my script using winscp.com can't.
I cannot tell that either from the log file.
The server seems to react differently to a different sequence of requests used by the script.
dhebert
Solution
I was using the following function to download a number of files from a WebDAV server:
$session.GetFiles( $remotePath + 'PSW*.csv', $localPath + "\" ).Check()
And received the same error:
Exception calling "Check" with "0" argument(s): "Error transferring file..
Solution:
This error went away when I narrowed the criteria to a specific file that I was certain was on the WebDAV server.
