Unknown switch 'resumesupport' error from cmd script
Tarinder
Sheffield, UK
Hi i get the following error when trying to upload a file
This is the full script:
option batch continue
open sftp://username:password@url -hostkey=theKey
option transfer binary
cd .
lcd c:\randomDirectory
put file.csv -resumesupport=off
close
I just found out the resumesupport option was introduced in 4.1 beta (https://winscp.net/eng/docs/faq_script_switch) but another user said it's available on 5.2 beta only.
Can you please tell me where this switch is available? I'm using version 5.1.3 (build 2881)
Can someone please help?
Re: Unknown switch 'resumesupport' error from cmd script
The only correct answer is: Use the latest version of WinSCP.
Btw, the FAQ says: Some specific switches (such as -resumesupport, -filemask, -rawsettings, etc.) were introduced even later.
