Put Command not working properly for multiple files
nbarr7655
United States
Hello all. I have a script that seems to work great when uploading a single file. However, on Monday's every week the script needs to upload two files, both with the same file extension just slightly different names.
As of right now the tail end of the script looks like this and like I said, works when uploading one single file but on Monday night when it needs to upload 2 files, it still only uploads one file.
# WinSCP script to upload files
# Set Options - abort on error, overwrite files
option batch abort
# open the connection ACME (Defined in Sites)
open ACME
# Set binary transfer
option transfer binary
# Transfer file
LCD y:\
put *.ACME
# Elvis has left the building
close
Using version 5.13.4 on Server 2012 R2 Standard
Re: Put Command not working properly for multiple files
nbarr7655
United States
Martin, attached is the log. Blanks throughout the log are just areas that I had removed information from. What I noted in the logs is that it starts out by saying that it sees two files and plans to upload them. It looks like it starts on the first and transfers it but gets stuck after that or something? In the logs I only see one of the file names listed but the other file name never appears and is never uploaded.
Description: log from upload
