How do I skip the abort timer?
                I use a script to run firmware upgrades on Ubiquity radios and then another script to apply configurations. After I upload the firmware and apply it, the radio reboots, and I get a disconnect message:
Host is not communicating for more than 15 seconds.
Still waiting...
Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
Warning: Aborting this operation will close connection!
(A)bort (60 s): Abort
Is there any way I can disable the 60 second timer? The reboot doesn't take 60 seconds, and I would like to start the next script as soon as the radio has rebooted. This does make a difference, when you have 100 radios to flash.
Still waiting...
