WinSCPnet.dll use without installing exe
secondfh
I'm want to call the WinSCPnet.dll in LabVIEW to perform an SFTP. I can only get it to work if WinSCP.exe has been installed on the PC. Would like to avoid having to install the exe. Is the .dll conditioned to perform this way?
WinSCP.SessionLocalException: The winscp.exe executable was not found at location of the assembly (C:\), nor in an installation path. You may use Session.ExecutablePath property to explicitly set path to winscp.exe. <append><b>WinSCP.SessionLocalException</b>
Re: WinSCPnet.dll use without installing exe
You do not have to install WinSCP. Just deploy a copy of WinSCP.exe along with your application.
Or use WinSCP NuGet package, which does it for you.
Or you can embed WinSCP.exe into your executable, if you want one-file solution only.
All these options are covered in documentation:
https://winscp.net/eng/docs/library_install
