Error using WinSCP With VB6 - TimeoutInMilliseconds
cadocfrm
Brasil
Somebody can help me.
I'm using WinSCP wiht VB6. When i set property TimeoutInMilliseconds of session is showed me error "Object doesn't support this property or method" I would like set timeout connection FTP.
Somebody alredy this problem?
Thank you
Reply with quote E-mail
Re: Error using WinSCP With VB6 - TimeoutInMilliseconds
1) Make sure you have the latest version (and only the latest version) of WinSCP .NET assembly registered.
2) Make sure you set the property on SessionOptions class, not Session.
