Different font sizes in different internal editor windows
James L
London
If I have two internal editor windows open (different files of course, but on the same monitor) the font size on one is sometimes biffer that the other (which is a little hard on the eye). If I change the font size in settings they both get bigger or smaller together.
Any ideas what is going on?
Re: Different font sizes in different internal editor windows
piprus85
Just to report, I've got exactly the same problem as @James L mentioned. The problem occurred with a version 6.1.1 and persists after update to 6.1.2 (@Windows 11Pro 22H2)
@piprus85: Thanks for your report.
