reporting a vulnerability
Piru
How should a vulnerability in WinSCP be reported?
I would want to keep embargo on the issue while the authors triage the issue, so posting it to this forum likely isn't a good idea.
Re: reporting a vulnerability
Thanks for your post.
I'm sending you an email to the address you have used to register on this forum.
Re: Fix for 5.13
@MrPippin: I'll consider it.
But to be honest, this is such a negligible problem.
Are you not trusting your server?
And are you actually using SCP protocol at all?
slfields
USA
Re: Fix for 5.13
The primary reason I ask is that version 14 is still considered a release candidate, and this is a product deployed widely in our organization. We can’t speak to what sites are users are connecting, or trusted.
