set as root of folder explorer
GOWAP
In the advanced connection options, you can specify the remote folder and the local folder with the possibility of storing the folders active at closing (remember the last folders used).
But this does not allow to define a root directory that prohibits in the folder explorer to go up on a parent folder (especially for remote).
Is the "root folder" option some things possible?
