Trying to automate get -delete
Roman Belousov
Hey guys, so I've created bunn_get.txt in C:\Program Files (x86)\WinSCP and it goes like this:
open sftp://<key>@ftp.axiscloudplatform.com/ -hostkey="ssh-rsa 2048 <another key>="
cd /out
lcd C:\GD\Emails\Bunnings
get -delete *.xml
#also tried get -delete *.xml C:\GD\Emails\Bunnings
# Execute the script using a command like:
# "C:\Program Files (x86)\WinSCP\WinSCP.exe" /log="C:\GD\Emails\Bunnings\archive\WinSCP.log" /ini=nul /script="C:\bunn_get.txt"
And I've created bunn_edi.bat in c:\
"C:\Program Files (x86)\WinSCP\WinSCP.exe" /log="C:\GD\Emails\Bunnings\archive\WinSCP.log" /ini=nul /script="C:\bunnings_get.txt
Nothing's happening. When I try to open the terminal window in WinSCP, I get the error:
Using username "<username>".
Authentication failed.
Any ideas?
My Regards
Roman
Candoo Business Systems
Roman Belousov
I was able to figure WinSCP automation out. For your info, here's what works:
  1. Get WinSCP to generate the script for you. You'll need the line at the top as that contains the SSL certificate as well as a properly-formatted user and password authentication.
  2. For some reason the instructions at the bottom of the file generated by WinSCP don't work, so instead do this;
  3. Create a batch file, in my case I saved in c:\. The file has the following 3 lines:
    cd\
    cd Program Files (x86)\WinSCP
    type get_script.txt | winscp
  4. create get_script.txt in Program Files (x86)\WinSCP (the standard directory it installs in), it contains the following 5 lines:
    open sftp://<the rest of that first line from step 1>
    cd /out
    lcd C:\XML
    get -delete *.xml
  5. your files will appear in C:\XML.
You have to use the type command in the batch file, simply listing the commands stops working as soon as you're in WinSCP's prompt (it has its own prompt).
I hope this comes in handy later, thank you and good luck.
My regards,
Roman Belousov
www.candoo.com.au
Can you please elaborate on the problem?
