Need Your Idea (Waiting for data timed out, asking user what to do.)
Akif in Istanbul
I will automation script. But I want execute command from windows to linux then encounter that mistake.
Can you help ?
, /u01/data/agito/Automation/calistir.sh ;
. 2018-07-24 08:25:39.107 [Shell] Waiting for data timed out, asking user what to do.
. 2018-07-24 08:25:39.107 [Shell] Asking user:
. 2018-07-24 08:25:39.107 [Shell] **Host is not communicating for 180 seconds.
. 2018-07-24 08:25:39.107 [Shell] Wait for another 180 seconds?** ()
< 2018-07-24 08:25:39.107 Script: Host is not communicating for more than 180 seconds.
< 2018-07-24 08:25:39.107 Still waiting...
< 2018-07-24 08:25:39.107 Note: If the problem repeats, try turning off 'Optimize connection buffer size'.
< 2018-07-24 08:25:39.107 Warning: Aborting this operation will close connection!
. 2018-07-24 08:26:38.659 [Shell] Attempt to close connection due to fatal exception:
* 2018-07-24 08:26:38.659 [Shell] **Terminated by user.**
. 2018-07-24 08:26:38.659 [Shell] Closing connection.
. 2018-07-24 08:26:38.659 [Shell] Sending special code: 12
. 2018-07-24 08:26:38.659 [Shell] Sent EOF message
< 2018-07-24 08:26:38.659 Script: Terminated by user.
. 2018-07-24 08:26:38.660 Closing connection.
. 2018-07-24 08:26:38.660 Sending special code: 12
. 2018-07-24 08:26:38.660 Sent EOF message
Re: Need Your Idea (Waiting for data timed out, asking user what to do.)
And how long does it take for the shell script to finish, when you execute it in SSH terminal?
Also does the script need any user input?
