Connection failed not returning an error code
ecommer
United States
I don't seem to getting an error code when the SFTP connection fails. (Server blocked me)
Script seems to work find otherwise - for example bad password etc.
Can someone please help me catch this error so that if it doesn't connect the batch file sees the error code.
script
# start script code
open sftp://myun:cfgfdgfdg9R@mysite.com
option transfer binary
cd pim
put \\Shares\Web\ItemUpdated\*.xml -preservetime
close
my_bat
"C:\Program Files (x86)\WinSCP\WinSCP.com" /console /script=C:\my_script.txt /log="C:\FileUpload\log\transfer.log" /logsize=5*10M
if %ERRORLEVEL% neq 0 goto error
echo Upload succeeded, moving local files to archive
move \\Shares\Web\ItemUpdated\*.xml \\Shares\Web\ItemProcessed
echo Removing any archive files older than 30 days
FORFILES /p "\\Shares\Web\ItemProcessed" /d -30 /m *.xml /c "cmd /c del @file"
exit 0
:error
echo Upload failed, keeping local files
exit 1
Log file looks all good. And I cannot reproduce your problem. It works just fine for me with your batch file. What version of Windows are you using?
ecommer
Windows Server 2012 R2 which is similar to Windows 10. We had a host blocking our ip which is when we noticed this. Otherwise yes it works fine on failed logins, etc.. weird. Thanks for looking into it
With /loglevel=1, it prints its exit code on output. Please test it, to see what WinSCP believes its exit code is.
