Get fingerprint with vb.net
Wilco
Amersfoort
Good afternoon,
I use vb.net and how can I retrieve the fingerprint from a server and put it in a variable?
Regards,
Wilco
AndMCS
Re: Get fingerprint with vb.net
I'm trying to use this method (scanfingerprint), however, I'm getting the following error message:
Error 1 'WinSCP.Session' does not contain a definition for 'ScanFingerprint' and no extension method 'ScanFingerprint' accepting a first argument of type 'WinSCP.Session' could be found (are you missing a using directive or an assembly reference?)
I installed WinSCPnet using Visual Studio Nuget Package Manager and the installed version is 5.7.5.
In addition, I tried to use the fingerprint generated by WinSCP UI on SessionOptions but it doesn't match with the validation regular expression.
Thanks,
So why didn't you install the latest version?
5.7.5 is 4 years old and does not have the Session.ScanFingerprint method.
