Hotkey to copy IMG https url
2fersen
Deutschland
Hello Guys,
is it possible to make a script to copy with: 'STRG + T' the HTTPS Url of a picture?
i have found this tool:
https://winscp.net/eng/docs/extension_generate_http_url
With it is possible to get https url, but you can work with it pretty slow and the window at the end where you can choose to open the url, copy the url, or just close the window is pretty useless for me.
A hotkey would be pretty great for me.
Could anyone help me do this?
best regards,
2fersen
Reply with quote E-mail
Re: Hotkey to copy IMG https url
In extensions options, you can configure it to copy the URL to clipboard without displaying the message box.
https://winscp.net/eng/docs/extension_generate_http_url#options
The next version of WinSCP will allow you to configure a keyboard shortcut for (any) extension:
https://winscp.net/tracker/1613
In the current version of WinSCP, you can add the shortcut by editing an extension file:
https://winscp.net/eng/docs/extension#syntax
Or I can send you a development build of 5.14, if you want.
