Host is not communicating for more than 15 seconds
bill_rowe_ottawa@hotmail.com
Canada
I hadn't used winscp for a while, installed the new version when prompted but i keep getting this error connecting to a Pi zero. I found and turned off the "Optimize connection buffer size." but the issue is still there.
what can i try?
marymac
Similar problem here
I've been using WinSCP for at least 10 years to administer servers on AWS and Digital Ocean, and have never had problems until recently. I was getting the problem you describe, where the application just closes itself (no error) when I've been connected to a server for 5-15 seconds. Updating to the latest version seemed to help.
Now it connects fine if I only browse around on the server, but if I try to access existing folders on my local hard drive the application hangs for a couple seconds with a flashlight icon then closes itself. No apparent errors. This is on Windows 10 Version 10.0.17134 Build 17134 (a recent version).
I've tried disabling Norton Security, in case that was blocking access to my local drive for some reason, but have been unable to resolve this. I was able to create a NEW folder on my computer from within WinSCP and that does NOT crash. But trying to open existing folders closes the app. If this were Linux I would suspect a permissions problem, but...Windows.
I've donated to WinSCP in the past because it's been so solid, but I'm ready to move to a different SCP app if I can't get this working. Any other ideas folks?
Thanks!
Re: Similar problem here
crg
Any resolution for this issue?
I also recently started experiencing this issue after using WinSCP for years. Installed a fresh copy on a different PC that also has FileZilla installed. WinSCP imported site from FZ so I know acount and password match. WinSCP will timeout but FileZilla connects.
Re: Any resolution for this issue?
Related:
https://winscp.net/tracker/1666
shashi
It works if u set the remote directory to a correct directory
I also faced the same issue with the latest version of winscp (5.15.3), earlier versions were working fine!!
It works if u set the remote directory to a correct directory, try with root (/) if you have access to it, you might have set it some directory like /home/dir1, which may not exist on the server and while trying to read this, winscp (latest version) hangs, really silly bug
Re: It works if u set the remote directory to a correct directory
