keep remote directory up to date... preserve timestamp
jkgraham
I've read all the posts I could find about this problem: Where during a "Keep remote directory up to date" operation, the file IS transferred, but then there is a permission denied error.
I've done some experimenting (with v3.7.6 b306) and it appears to be that the Preserve Timestamp is NOT turned off when you run "Keep remote up to date".
When I transfer the CForms.xmap file manually (with both Set Permissions and Preserve Timestamp OFF), it works fine. And when I transfer manually and have turned Preserve Timestamp ON it fails with the Permission Denied and Error Code: 3. See first log file below.
Then when I try to do the "Keep remote up to date" I have triple checked that both Set Permissions and Preserve Timestamp are OFF it gives the same Permission Denied error after it detects the change and tries to transfer the file! See second log file... when it does the transfer, PrTime: Yes.
Thanks,
-Jon
ps. Great Program!
Manual Transfer of CForms.xmap with Presere Timestamp ON, then with it OFF
. 2005-12-05 12:36:13.783 --------------------------------------------------------------------------
. 2005-12-05 12:36:13.783 WinSCP Version 3.7.6 (Build 306) (OS 5.1.2600 Service Pack 2)
. 2005-12-05 12:36:13.783 Login time: Monday, December 05, 2005 12:36:13 PM
. 2005-12-05 12:36:13.783 Session name: klamath@dev.klamath.wd-2.net
. 2005-12-05 12:36:13.783 Host name: dev.klamath.wd-2.net (Port: 22)
. 2005-12-05 12:36:13.783 User name: klamath (Password: Yes, Key file: No)
. 2005-12-05 12:36:13.783 Transfer Protocol: SFTP (SCP)
. 2005-12-05 12:36:13.783 SSH protocol version: 2; Compression: No
. 2005-12-05 12:36:13.783 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-12-05 12:36:13.783 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-12-05 12:36:13.783 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-12-05 12:36:13.783 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-12-05 12:36:13.783 SFTP Bugs: -,-,-
. 2005-12-05 12:36:13.783 Proxy: none
. 2005-12-05 12:36:13.783 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-12-05 12:36:13.783 Shell: default, EOL: 0
. 2005-12-05 12:36:13.783 Local directory: default, Remote directory: /Volumes/data1/wd/projects/Klamath/site/dev/webapp, Update: No, Cache: Yes
. 2005-12-05 12:36:13.783 Cache directory changes: Yes, Permanent: No
. 2005-12-05 12:36:13.783 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-12-05 12:36:13.783 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-12-05 12:36:13.783 Looking up host "dev.klamath.wd-2.net"
. 2005-12-05 12:36:13.783 Connecting to 207.162.210.54 port 22
. 2005-12-05 12:36:15.158 Server version: SSH-2.0-OpenSSH_3.6.1p1+CAN-2003-0693
. 2005-12-05 12:36:15.158 We claim version: SSH-2.0-WinSCP_release_3.7.6
. 2005-12-05 12:36:15.158 Using SSH protocol version 2
. 2005-12-05 12:36:15.471 Doing Diffie-Hellman group exchange
. 2005-12-05 12:36:16.299 Doing Diffie-Hellman key exchange
. 2005-12-05 12:36:18.830 Host key fingerprint is:
. 2005-12-05 12:36:18.830 ssh-rsa 1024 e6:80:97:5a:a0:0d:c8:71:4d:ed:fb:3a:c6:a8:2f:79
. 2005-12-05 12:36:18.830 Initialised AES-256 client->server encryption
. 2005-12-05 12:36:18.830 Initialised HMAC-SHA1 client->server MAC algorithm
. 2005-12-05 12:36:18.830 Initialised AES-256 server->client encryption
. 2005-12-05 12:36:18.830 Initialised HMAC-SHA1 server->client MAC algorithm
! 2005-12-05 12:36:19.517 Using username "klamath".
. 2005-12-05 12:36:20.486 Keyboard-interactive authentication refused
. 2005-12-05 12:36:20.486 Session password prompt (klamath@dev.klamath.wd-2.net's password: )
. 2005-12-05 12:36:20.486 Using stored password.
. 2005-12-05 12:36:20.486 Sent password
. 2005-12-05 12:36:21.049 Access granted
. 2005-12-05 12:36:21.424 Opened channel for session
. 2005-12-05 12:36:21.783 Started a shell/command
. 2005-12-05 12:36:21.783 --------------------------------------------------------------------------
. 2005-12-05 12:36:21.783 Using SFTP protocol.
. 2005-12-05 12:36:21.783 Doing startup conversation with host.
> 2005-12-05 12:36:21.783 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2005-12-05 12:36:22.095 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2005-12-05 12:36:22.095 SFTP version 3 negotiated.
. 2005-12-05 12:36:22.095 We believe the server has signed timestamps bug
. 2005-12-05 12:36:22.095 We will use UTF-8 strings for status messages only
. 2005-12-05 12:36:22.095 Limiting packet size to OpenSSH limit of 262148 bytes
. 2005-12-05 12:36:22.095 Changing directory to "/Volumes/data1/wd/projects/Klamath/site/dev/webapp".
. 2005-12-05 12:36:22.095 Getting real path for '/Volumes/data1/wd/projects/Klamath/site/dev/webapp'
> 2005-12-05 12:36:22.095 Type: SSH_FXP_REALPATH, Size: 59, Number: 8720
< 2005-12-05 12:36:22.424 Type: SSH_FXP_NAME, Size: 121, Number: 8720
. 2005-12-05 12:36:22.424 Real path is '/Volumes/data1/wd/projects/Klamath/site/dev/webapp'
. 2005-12-05 12:36:22.424 Trying to open directory "/Volumes/data1/wd/projects/Klamath/site/dev/webapp".
> 2005-12-05 12:36:22.424 Type: SSH_FXP_LSTAT, Size: 59, Number: 8967
< 2005-12-05 12:36:22.752 Type: SSH_FXP_ATTRS, Size: 37, Number: 8967
. 2005-12-05 12:36:22.752 Getting current directory name.
. 2005-12-05 12:36:22.752 Listing directory "/Volumes/data1/wd/projects/Klamath/site/dev/webapp".
> 2005-12-05 12:36:22.752 Type: SSH_FXP_OPENDIR, Size: 59, Number: 9227
< 2005-12-05 12:36:23.080 Type: SSH_FXP_HANDLE, Size: 13, Number: 9227
> 2005-12-05 12:36:23.080 Type: SSH_FXP_READDIR, Size: 13, Number: 9484
< 2005-12-05 12:36:23.783 Type: SSH_FXP_NAME, Size: 1881, Number: 9484
> 2005-12-05 12:36:23.783 Type: SSH_FXP_READDIR, Size: 13, Number: 9740
. 2005-12-05 12:36:23.783 Reading symlink "config".
> 2005-12-05 12:36:23.783 Type: SSH_FXP_READLINK, Size: 66, Number: 10003
> 2005-12-05 12:36:23.783 Type: SSH_FXP_STAT, Size: 66, Number: 10257
< 2005-12-05 12:36:24.064 Type: SSH_FXP_STATUS, Size: 28, Number: 9740
. 2005-12-05 12:36:24.064 Storing reserved response
< 2005-12-05 12:36:24.408 Type: SSH_FXP_NAME, Size: 39, Number: 10003
< 2005-12-05 12:36:24.408 Type: SSH_FXP_ATTRS, Size: 37, Number: 10257
< 2005-12-05 12:36:24.408 Status/error code: 1
> 2005-12-05 12:36:24.408 Type: SSH_FXP_CLOSE, Size: 13, Number: 10500
. 2005-12-05 12:36:24.408 Startup conversation with host finished.
. 2005-12-05 12:36:24.408 Copying 1 files/directories to remote directory "/Volumes/data1/wd/projects/Klamath/site/dev/webapp/"
. 2005-12-05 12:36:24.408   PrTime: Yes; PrRO: No; Rght: rw-rw-r--; PrR: No; FnCs: N; RIC: 00; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2005-12-05 12:36:24.408   TM: M; ClAr: No; ExclM(No): .svn/
. 2005-12-05 12:36:24.408   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2005-12-05 12:36:24.408 File: "E:\dev\wrinkledog\dev\webapp\CForms.xmap"
. 2005-12-05 12:36:24.408 Copying "E:\dev\wrinkledog\dev\webapp\CForms.xmap" to remote directory started.
. 2005-12-05 12:36:24.408 Binary transfer mode selected.
. 2005-12-05 12:36:24.408 Opening remote file.
> 2005-12-05 12:36:24.408 Type: SSH_FXP_OPEN, Size: 87, Number: 10755
< 2005-12-05 12:36:24.736 Type: SSH_FXP_STATUS, Size: 24, Number: 10500
. 2005-12-05 12:36:24.736 Discarding reserved response
< 2005-12-05 12:36:25.049 Type: SSH_FXP_HANDLE, Size: 13, Number: 10755
> 2005-12-05 12:36:25.049 Type: SSH_FXP_WRITE, Size: 935, Number: 11270
. 2005-12-05 12:36:25.830 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2005-12-05 12:36:25.830 Type: SSH_FXP_CLOSE, Size: 13, Number: 11524
> 2005-12-05 12:36:25.830 Type: SSH_FXP_SETSTAT, Size: 83, Number: 11017
< 2005-12-05 12:36:26.111 Type: SSH_FXP_STATUS, Size: 24, Number: 11524
< 2005-12-05 12:36:26.111 Status/error code: 0
< 2005-12-05 12:36:26.392 Type: SSH_FXP_STATUS, Size: 34, Number: 11017
< 2005-12-05 12:36:26.392 Status/error code: 3, Message: 11017, Server: Permission denied, Language:
* 2005-12-05 12:36:26.392 (ETerminal) Permission denied.
* 2005-12-05 12:36:26.392 Error code: 3
* 2005-12-05 12:36:26.392 Error message from server: Permission denied
* 2005-12-05 12:36:26.392 Request code: 9
. 2005-12-05 12:36:26.392 Asking user:
. 2005-12-05 12:36:26.392 Upload of file 'CForms.xmap' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off 'Set permissions' and/or 'Preserve timestamp' option. ("Permission denied.
. 2005-12-05 12:36:26.392 Error code: 3
. 2005-12-05 12:36:26.392 Error message from server: Permission denied
. 2005-12-05 12:36:26.392 Request code: 9")
* 2005-12-05 12:36:28.970 (EScpSkipFile) Upload of file 'CForms.xmap' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off 'Set permissions' and/or 'Preserve timestamp' option.
* 2005-12-05 12:36:28.970 Permission denied.
* 2005-12-05 12:36:28.970 Error code: 3
* 2005-12-05 12:36:28.970 Error message from server: Permission denied
* 2005-12-05 12:36:28.970 Request code: 9
. 2005-12-05 12:36:28.970 Listing directory "/Volumes/data1/wd/projects/Klamath/site/dev/webapp".
> 2005-12-05 12:36:28.970 Type: SSH_FXP_OPENDIR, Size: 59, Number: 11787
< 2005-12-05 12:36:29.283 Type: SSH_FXP_HANDLE, Size: 13, Number: 11787
> 2005-12-05 12:36:29.283 Type: SSH_FXP_READDIR, Size: 13, Number: 12044
< 2005-12-05 12:36:29.580 Type: SSH_FXP_NAME, Size: 1881, Number: 12044
> 2005-12-05 12:36:29.580 Type: SSH_FXP_READDIR, Size: 13, Number: 12300
. 2005-12-05 12:36:29.580 Reading symlink "config".
> 2005-12-05 12:36:29.580 Type: SSH_FXP_READLINK, Size: 66, Number: 12563
> 2005-12-05 12:36:29.580 Type: SSH_FXP_STAT, Size: 66, Number: 12817
< 2005-12-05 12:36:29.908 Type: SSH_FXP_STATUS, Size: 28, Number: 12300
. 2005-12-05 12:36:29.908 Storing reserved response
< 2005-12-05 12:36:30.236 Type: SSH_FXP_NAME, Size: 39, Number: 12563
< 2005-12-05 12:36:30.236 Type: SSH_FXP_ATTRS, Size: 37, Number: 12817
< 2005-12-05 12:36:30.236 Status/error code: 1
> 2005-12-05 12:36:30.236 Type: SSH_FXP_CLOSE, Size: 13, Number: 13060
. 2005-12-05 12:36:30.986 Detected incoming data while idle
. 2005-12-05 12:39:00.701 Copying 1 files/directories to remote directory "/Volumes/data1/wd/projects/Klamath/site/dev/webapp/"
. 2005-12-05 12:39:00.701   PrTime: No; PrRO: No; Rght: rw-rw-r--; PrR: No; FnCs: N; RIC: 00; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2005-12-05 12:39:00.701   TM: M; ClAr: No; ExclM(No): .svn/
. 2005-12-05 12:39:00.701   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2005-12-05 12:39:00.701 File: "E:\dev\wrinkledog\dev\webapp\CForms.xmap"
. 2005-12-05 12:39:00.701 Copying "E:\dev\wrinkledog\dev\webapp\CForms.xmap" to remote directory started.
. 2005-12-05 12:39:00.701 Binary transfer mode selected.
. 2005-12-05 12:39:00.701 Opening remote file.
> 2005-12-05 12:39:00.701 Type: SSH_FXP_OPEN, Size: 87, Number: 13315
< 2005-12-05 12:39:00.701 Type: SSH_FXP_STATUS, Size: 24, Number: 13060
. 2005-12-05 12:39:00.701 Discarding reserved response
< 2005-12-05 12:39:01.045 Type: SSH_FXP_HANDLE, Size: 13, Number: 13315
> 2005-12-05 12:39:01.045 Type: SSH_FXP_WRITE, Size: 959, Number: 13830
. 2005-12-05 12:39:01.951 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2005-12-05 12:39:01.951 Type: SSH_FXP_CLOSE, Size: 13, Number: 14084
< 2005-12-05 12:39:02.326 Type: SSH_FXP_STATUS, Size: 24, Number: 14084
< 2005-12-05 12:39:02.326 Status/error code: 0
. 2005-12-05 12:39:02.326 Listing directory "/Volumes/data1/wd/projects/Klamath/site/dev/webapp".
> 2005-12-05 12:39:02.326 Type: SSH_FXP_OPENDIR, Size: 59, Number: 14347
< 2005-12-05 12:39:02.701 Type: SSH_FXP_HANDLE, Size: 13, Number: 14347
> 2005-12-05 12:39:02.701 Type: SSH_FXP_READDIR, Size: 13, Number: 14604
< 2005-12-05 12:39:03.623 Type: SSH_FXP_NAME, Size: 1881, Number: 14604
> 2005-12-05 12:39:03.623 Type: SSH_FXP_READDIR, Size: 13, Number: 14860
. 2005-12-05 12:39:03.623 Reading symlink "config".
> 2005-12-05 12:39:03.623 Type: SSH_FXP_READLINK, Size: 66, Number: 15123
> 2005-12-05 12:39:03.623 Type: SSH_FXP_STAT, Size: 66, Number: 15377
< 2005-12-05 12:39:03.935 Type: SSH_FXP_STATUS, Size: 28, Number: 14860
. 2005-12-05 12:39:03.935 Storing reserved response
< 2005-12-05 12:39:04.248 Type: SSH_FXP_NAME, Size: 39, Number: 15123
< 2005-12-05 12:39:04.248 Type: SSH_FXP_ATTRS, Size: 37, Number: 15377
< 2005-12-05 12:39:04.248 Status/error code: 1
> 2005-12-05 12:39:04.248 Type: SSH_FXP_CLOSE, Size: 13, Number: 15620
. 2005-12-05 12:39:04.982 Detected incoming data while idle
"Keep remote directory up to date" log file, note PrTime: Yes
. 2005-12-05 12:58:55.139 Closing connection.
. 2005-12-05 12:58:56.733 --------------------------------------------------------------------------
. 2005-12-05 12:58:56.733 WinSCP Version 3.7.6 (Build 306) (OS 5.1.2600 Service Pack 2)
. 2005-12-05 12:58:56.733 Login time: Monday, December 05, 2005 12:58:56 PM
. 2005-12-05 12:58:56.733 Session name: klamath@dev.klamath.wd-2.net
. 2005-12-05 12:58:56.733 Host name: dev.klamath.wd-2.net (Port: 22)
. 2005-12-05 12:58:56.733 User name: klamath (Password: Yes, Key file: No)
. 2005-12-05 12:58:56.733 Transfer Protocol: SFTP (SCP)
. 2005-12-05 12:58:56.733 SSH protocol version: 2; Compression: No
. 2005-12-05 12:58:56.733 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-12-05 12:58:56.733 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-12-05 12:58:56.733 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-12-05 12:58:56.733 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-12-05 12:58:56.733 SFTP Bugs: -,-,-
. 2005-12-05 12:58:56.733 Proxy: none
. 2005-12-05 12:58:56.733 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-12-05 12:58:56.733 Shell: default, EOL: 0
. 2005-12-05 12:58:56.733 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-12-05 12:58:56.733 Cache directory changes: Yes, Permanent: Yes
. 2005-12-05 12:58:56.733 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-12-05 12:58:56.733 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-12-05 12:58:56.733 Looking up host "dev.klamath.wd-2.net"
. 2005-12-05 12:58:56.733 Connecting to 207.162.210.54 port 22
. 2005-12-05 12:58:57.405 Server version: SSH-2.0-OpenSSH_3.6.1p1+CAN-2003-0693
. 2005-12-05 12:58:57.405 We claim version: SSH-2.0-WinSCP_release_3.7.6
. 2005-12-05 12:58:57.405 Using SSH protocol version 2
. 2005-12-05 12:58:57.717 Doing Diffie-Hellman group exchange
. 2005-12-05 12:58:58.498 Doing Diffie-Hellman key exchange
. 2005-12-05 12:59:00.029 Host key fingerprint is:
. 2005-12-05 12:59:00.029 ssh-rsa 1024 e6:80:97:5a:a0:0d:c8:71:4d:ed:fb:3a:c6:a8:2f:79
. 2005-12-05 12:59:00.029 Initialised AES-256 client->server encryption
. 2005-12-05 12:59:00.029 Initialised HMAC-SHA1 client->server MAC algorithm
. 2005-12-05 12:59:00.029 Initialised AES-256 server->client encryption
. 2005-12-05 12:59:00.029 Initialised HMAC-SHA1 server->client MAC algorithm
! 2005-12-05 12:59:00.811 Using username "klamath".
. 2005-12-05 12:59:01.639 Keyboard-interactive authentication refused
. 2005-12-05 12:59:01.639 Session password prompt (klamath@dev.klamath.wd-2.net's password: )
. 2005-12-05 12:59:01.639 Using stored password.
. 2005-12-05 12:59:01.639 Sent password
. 2005-12-05 12:59:02.217 Access granted
. 2005-12-05 12:59:02.561 Opened channel for session
. 2005-12-05 12:59:02.936 Started a shell/command
. 2005-12-05 12:59:02.936 --------------------------------------------------------------------------
. 2005-12-05 12:59:02.983 Using SFTP protocol.
. 2005-12-05 12:59:02.983 Doing startup conversation with host.
> 2005-12-05 12:59:02.998 Type: SSH_FXP_INIT, Size: 5, Number: -1
< 2005-12-05 12:59:03.358 Type: SSH_FXP_VERSION, Size: 5, Number: -1
. 2005-12-05 12:59:03.358 SFTP version 3 negotiated.
. 2005-12-05 12:59:03.358 We believe the server has signed timestamps bug
. 2005-12-05 12:59:03.358 We will use UTF-8 strings for status messages only
. 2005-12-05 12:59:03.358 Limiting packet size to OpenSSH limit of 262148 bytes
. 2005-12-05 12:59:03.358 Getting current directory name.
. 2005-12-05 12:59:03.358 Getting real path for '.'
> 2005-12-05 12:59:03.358 Type: SSH_FXP_REALPATH, Size: 10, Number: 1296
< 2005-12-05 12:59:03.717 Type: SSH_FXP_NAME, Size: 99, Number: 1296
. 2005-12-05 12:59:03.717 Real path is '/Volumes/data1/wd/projects/Klamath/site'
. 2005-12-05 12:59:03.717 Listing directory "/Volumes/data1/wd/projects/Klamath/site".
> 2005-12-05 12:59:03.717 Type: SSH_FXP_OPENDIR, Size: 48, Number: 1547
< 2005-12-05 12:59:05.857 Type: SSH_FXP_HANDLE, Size: 13, Number: 1547
> 2005-12-05 12:59:05.857 Type: SSH_FXP_READDIR, Size: 13, Number: 1804
< 2005-12-05 12:59:06.529 Type: SSH_FXP_NAME, Size: 833, Number: 1804
> 2005-12-05 12:59:06.529 Type: SSH_FXP_READDIR, Size: 13, Number: 2060
< 2005-12-05 12:59:06.826 Type: SSH_FXP_STATUS, Size: 28, Number: 2060
< 2005-12-05 12:59:06.826 Status/error code: 1
> 2005-12-05 12:59:06.826 Type: SSH_FXP_CLOSE, Size: 13, Number: 2308
. 2005-12-05 12:59:06.826 Startup conversation with host finished.
. 2005-12-05 12:59:07.154 Detected incoming data while idle
. 2005-12-05 12:59:10.435 Cached directory change via "dev" to "/Volumes/data1/wd/projects/Klamath/site/dev".
. 2005-12-05 12:59:10.435 Getting current directory name.
. 2005-12-05 12:59:10.435 Listing directory "/Volumes/data1/wd/projects/Klamath/site/dev".
> 2005-12-05 12:59:10.435 Type: SSH_FXP_OPENDIR, Size: 52, Number: 2571
< 2005-12-05 12:59:10.435 Type: SSH_FXP_STATUS, Size: 24, Number: 2308
. 2005-12-05 12:59:10.435 Discarding reserved response
< 2005-12-05 12:59:10.748 Type: SSH_FXP_HANDLE, Size: 13, Number: 2571
> 2005-12-05 12:59:10.748 Type: SSH_FXP_READDIR, Size: 13, Number: 2828
< 2005-12-05 12:59:11.123 Type: SSH_FXP_NAME, Size: 2055, Number: 2828
> 2005-12-05 12:59:11.123 Type: SSH_FXP_READDIR, Size: 13, Number: 3084
. 2005-12-05 12:59:11.123 Reading symlink "cocoon".
> 2005-12-05 12:59:11.123 Type: SSH_FXP_READLINK, Size: 59, Number: 3347
> 2005-12-05 12:59:11.123 Type: SSH_FXP_STAT, Size: 59, Number: 3601
< 2005-12-05 12:59:11.482 Type: SSH_FXP_STATUS, Size: 28, Number: 3084
. 2005-12-05 12:59:11.482 Storing reserved response
< 2005-12-05 12:59:11.857 Type: SSH_FXP_NAME, Size: 121, Number: 3347
< 2005-12-05 12:59:11.857 Type: SSH_FXP_ATTRS, Size: 37, Number: 3601
< 2005-12-05 12:59:11.857 Status/error code: 1
> 2005-12-05 12:59:11.857 Type: SSH_FXP_CLOSE, Size: 13, Number: 3844
. 2005-12-05 12:59:12.654 Detected incoming data while idle
. 2005-12-05 12:59:17.935 Cached directory change via "webapp" to "/Volumes/data1/wd/projects/Klamath/site/dev/webapp".
. 2005-12-05 12:59:17.935 Getting current directory name.
. 2005-12-05 12:59:17.935 Listing directory "/Volumes/data1/wd/projects/Klamath/site/dev/webapp".
> 2005-12-05 12:59:17.951 Type: SSH_FXP_OPENDIR, Size: 59, Number: 4107
< 2005-12-05 12:59:17.951 Type: SSH_FXP_STATUS, Size: 24, Number: 3844
. 2005-12-05 12:59:17.951 Discarding reserved response
< 2005-12-05 12:59:18.279 Type: SSH_FXP_HANDLE, Size: 13, Number: 4107
> 2005-12-05 12:59:18.279 Type: SSH_FXP_READDIR, Size: 13, Number: 4364
< 2005-12-05 12:59:18.670 Type: SSH_FXP_NAME, Size: 1881, Number: 4364
> 2005-12-05 12:59:18.670 Type: SSH_FXP_READDIR, Size: 13, Number: 4620
. 2005-12-05 12:59:18.670 Reading symlink "config".
> 2005-12-05 12:59:18.670 Type: SSH_FXP_READLINK, Size: 66, Number: 4883
> 2005-12-05 12:59:18.670 Type: SSH_FXP_STAT, Size: 66, Number: 5137
< 2005-12-05 12:59:19.060 Type: SSH_FXP_STATUS, Size: 28, Number: 4620
. 2005-12-05 12:59:19.060 Storing reserved response
< 2005-12-05 12:59:19.404 Type: SSH_FXP_NAME, Size: 39, Number: 4883
< 2005-12-05 12:59:19.404 Type: SSH_FXP_ATTRS, Size: 37, Number: 5137
< 2005-12-05 12:59:19.404 Status/error code: 1
> 2005-12-05 12:59:19.404 Type: SSH_FXP_CLOSE, Size: 13, Number: 5380
. 2005-12-05 12:59:20.154 Detected incoming data while idle
. 2005-12-05 12:59:27.857 Synchronizing local directory 'E:\dev\wrinkledog\dev\webapp' with remote directory '/Volumes/data1/wd/projects/Klamath/site/dev/webapp', mode = 0, params = 2054
. 2005-12-05 12:59:27.857 Listing directory "/Volumes/data1/wd/projects/Klamath/site/dev/webapp".
> 2005-12-05 12:59:27.857 Type: SSH_FXP_OPENDIR, Size: 59, Number: 5643
< 2005-12-05 12:59:27.857 Type: SSH_FXP_STATUS, Size: 24, Number: 5380
. 2005-12-05 12:59:27.857 Discarding reserved response
< 2005-12-05 12:59:28.201 Type: SSH_FXP_HANDLE, Size: 13, Number: 5643
> 2005-12-05 12:59:28.201 Type: SSH_FXP_READDIR, Size: 13, Number: 5900
< 2005-12-05 12:59:28.544 Type: SSH_FXP_NAME, Size: 1881, Number: 5900
> 2005-12-05 12:59:28.544 Type: SSH_FXP_READDIR, Size: 13, Number: 6156
. 2005-12-05 12:59:28.560 Reading symlink "config".
> 2005-12-05 12:59:28.560 Type: SSH_FXP_READLINK, Size: 66, Number: 6419
> 2005-12-05 12:59:28.560 Type: SSH_FXP_STAT, Size: 66, Number: 6673
< 2005-12-05 12:59:28.919 Type: SSH_FXP_STATUS, Size: 28, Number: 6156
. 2005-12-05 12:59:28.919 Storing reserved response
< 2005-12-05 12:59:29.279 Type: SSH_FXP_NAME, Size: 39, Number: 6419
< 2005-12-05 12:59:29.279 Type: SSH_FXP_ATTRS, Size: 37, Number: 6673
< 2005-12-05 12:59:29.279 Status/error code: 1
> 2005-12-05 12:59:29.279 Type: SSH_FXP_CLOSE, Size: 13, Number: 6916
. 2005-12-05 12:59:30.154 Detected incoming data while idle
. 2005-12-05 12:59:32.951 Synchronizing local directory 'E:\dev\wrinkledog\dev\webapp\' with remote directory '/Volumes/data1/wd/projects/Klamath/site/dev/webapp/', mode = 0, params = 2238
. 2005-12-05 12:59:33.029 Copying 1 files/directories to remote directory "/Volumes/data1/wd/projects/Klamath/site/dev/webapp/"
. 2005-12-05 12:59:33.029   PrTime: Yes; PrRO: No; Rght: rw-rw-r--; PrR: No; FnCs: N; RIC: 00; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2005-12-05 12:59:33.029   TM: M; ClAr: No; ExclM(No): .svn/
. 2005-12-05 12:59:33.029   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2005-12-05 12:59:33.029 File: "E:\dev\wrinkledog\dev\webapp\CForms.xmap"
. 2005-12-05 12:59:33.029 Copying "E:\dev\wrinkledog\dev\webapp\CForms.xmap" to remote directory started.
. 2005-12-05 12:59:33.029 Binary transfer mode selected.
. 2005-12-05 12:59:33.029 Opening remote file.
> 2005-12-05 12:59:33.029 Type: SSH_FXP_OPEN, Size: 87, Number: 7171
< 2005-12-05 12:59:33.029 Type: SSH_FXP_STATUS, Size: 24, Number: 6916
. 2005-12-05 12:59:33.029 Discarding reserved response
< 2005-12-05 12:59:33.372 Type: SSH_FXP_HANDLE, Size: 13, Number: 7171
> 2005-12-05 12:59:33.372 Type: SSH_FXP_WRITE, Size: 937, Number: 7686
. 2005-12-05 12:59:34.232 1 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2005-12-05 12:59:34.232 Type: SSH_FXP_CLOSE, Size: 13, Number: 7940
> 2005-12-05 12:59:34.232 Type: SSH_FXP_SETSTAT, Size: 83, Number: 7433
< 2005-12-05 12:59:34.575 Type: SSH_FXP_STATUS, Size: 24, Number: 7940
< 2005-12-05 12:59:34.575 Status/error code: 0
< 2005-12-05 12:59:34.919 Type: SSH_FXP_STATUS, Size: 34, Number: 7433
< 2005-12-05 12:59:34.919 Status/error code: 3, Message: 7433, Server: Permission denied, Language:
* 2005-12-05 12:59:34.919 (ETerminal) Permission denied.
* 2005-12-05 12:59:34.919 Error code: 3
* 2005-12-05 12:59:34.919 Error message from server: Permission denied
* 2005-12-05 12:59:34.919 Request code: 9
. 2005-12-05 12:59:34.982 Asking user:
. 2005-12-05 12:59:34.982 Upload of file 'CForms.xmap' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off 'Set permissions' and/or 'Preserve timestamp' option. ("Permission denied.
. 2005-12-05 12:59:34.982 Error code: 3
. 2005-12-05 12:59:34.982 Error message from server: Permission denied
. 2005-12-05 12:59:34.982 Request code: 9")
* 2005-12-05 13:00:20.449 (EScpSkipFile) Upload of file 'CForms.xmap' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn off 'Set permissions' and/or 'Preserve timestamp' option.
* 2005-12-05 13:00:20.449 Permission denied.
* 2005-12-05 13:00:20.449 Error code: 3
* 2005-12-05 13:00:20.449 Error message from server: Permission denied
* 2005-12-05 13:00:20.449 Request code: 9
. 2005-12-05 13:00:20.465 Listing directory "/Volumes/data1/wd/projects/Klamath/site/dev/webapp".
> 2005-12-05 13:00:20.465 Type: SSH_FXP_OPENDIR, Size: 59, Number: 8203
< 2005-12-05 13:00:20.824 Type: SSH_FXP_HANDLE, Size: 13, Number: 8203
> 2005-12-05 13:00:20.824 Type: SSH_FXP_READDIR, Size: 13, Number: 8460
< 2005-12-05 13:00:21.574 Type: SSH_FXP_NAME, Size: 1881, Number: 8460
> 2005-12-05 13:00:21.574 Type: SSH_FXP_READDIR, Size: 13, Number: 8716
. 2005-12-05 13:00:21.574 Reading symlink "config".
> 2005-12-05 13:00:21.574 Type: SSH_FXP_READLINK, Size: 66, Number: 8979
> 2005-12-05 13:00:21.574 Type: SSH_FXP_STAT, Size: 66, Number: 9233
< 2005-12-05 13:00:21.887 Type: SSH_FXP_STATUS, Size: 28, Number: 8716
. 2005-12-05 13:00:21.887 Storing reserved response
< 2005-12-05 13:00:22.230 Type: SSH_FXP_NAME, Size: 39, Number: 8979
< 2005-12-05 13:00:22.230 Type: SSH_FXP_ATTRS, Size: 37, Number: 9233
< 2005-12-05 13:00:22.230 Status/error code: 1
> 2005-12-05 13:00:22.230 Type: SSH_FXP_CLOSE, Size: 13, Number: 9476
. 2005-12-05 13:00:22.871 Detected incoming data while idle
. 2005-12-05 13:00:25.371 Closing connection.
Re: keep remote directory up to date... preserve timestamp
Yes, that's true. The function would not work without "preserve timestamp" turned on. So it is forced, despite the user settings.
jkgraham wrote:
So is this considered a bug, or is it just the way it works?
It is the way it works. Of course, it's bit a bug that you are allowed to turn the option off, if it is considered on nevertheless. Also it may be reasonable to let it be off, if size is used as comparison criteria. So there are things to improve. Thanks for bringing my attention to it :-)
