GID and UID no longer displayed in file properties
probreport
I always used SFTP to connect remote machines and i always got UID and GID within file preferences.
Now i switch from SFTP to SCP and UID and GID are no longer shown in file preferences.
If i switch back to SFTP they are shown again.
If i create a completely new connection which was never created in WinSCP i get no UID and no GID no matter if i use SFTP or SCP.
Re: GID and UID no longer displayed in file properties
probreport
requested logfile
Hi Martin,
attached the requested log.
Greets,
Thomas
  • 0_Produktion-(PU)-Zentral-ARCO-arcodblb---LIBELLE.log (12.99 KB, Private file)
Re: requested logfile
Did some further testing.
Seems to be a problem relatet to SCP. If i use SFTP instead of SCP the GID and UID are displayed. But this does not solve the problem. I can see the UID and GID but i can't get everywhere in the file system because i am not root.
Sorry, I do not understand what you mean by this.
It means that i can see UID and GID if i use SFTP but i can't change directories because i am not user "root". So i switched to SCP using "sudo -i" as SCP(Shell). Now i can change directories but can't see UID and GID anymore.
With SCP protocol, WinSCP does not show UID/GID. That's as expected.
I've asked for an SFTP log file, because of "If i create a completely new connection which was never created in WinSCP i get no UID and no GID no matter if i use SFTP or SCP."
