local file explorer stops working after a while
dkwebseditag
When using WinSCP (all versions up to 5.13.3 with open single or multiple connections but without active transfers in "idle" mode) the local explorer navigation stops working after some hours. I am working in explorer view. It's not possible to change to an other (sub-)folder, manual select a folder etc. No error message. Browsing the remote folders, copy to the "frozen" local folder etc. is still possible. Only way to get a working state is to cancel all open connections and to restart WinSCP.
Re: local file explorer stops working after a while
