spinning cursor when aborting a connection
Sopor
Sopor avatar
Sweden
If i connect to non existing site (or i enter the wrong site address or if the site goes down) WinSCP tries to search for the host. If i now press the red X in the upper right corner the window close, but now i get a spinning wheel cursor. As soon as the focus is on WinSCP the spinning cursor is back. It won't go back to an arrow until i restart WinSCP.
I'm running Windows 8.1 64-bit and WinSCP 5.13.3
Re: spinning cursor when aborting a connection
I cannot reproduce this. Can you provide us step-by-step instructions for reproducing the problem?
Sopor
Sopor avatar
Sweden
First of all you need to have more than one working connection open already (this could be the reason you didn't manage to reproduce it?).
Open a new session and connect to an address that don't exists.
When it tries to connect, press the red X to close the window.
You should now get the spinning cursor (busy).
