PowerShell Length Calculation Incorrect Using WinSCP assembly
Travisty54
Nashville
I ran into an interesting problem that I'm not sure if it's a bug or if I'm just doing something incorrect.
I have a need to pull a file via sFTP and have decided to script it using powershell with the WinSCP dll so I can have the best of both.
I start off by enumerating through the remote files.
# Begin transfer and logging of file.
$FileNames = $session.EnumerateRemoteFiles($FTPPath,"",[WinSCP.EnumerationOptions]::None)
$Files = $FileNames.FullName
Then I foreach through the files:
      ForEach ($File in $Files)
            # Transfer File and log both size and transfer time.
            $FileLength = $File.Length
            $FileLength
Unfortunately, the value I end up with for the length of the source file is double what the length actually is. I'm getting a value of 52KB while the file is actually 25KB and change.
My goal is to compare a file before and after transfer to validate that the file transferred properly. Can anyone shed light on what I'm doing wrong with the length or suggest a better way to compare pre and post transfer files?
Super appreciated
Reply with quote E-mail
Re: PowerShell Length Calculation Incorrect Using WinSCP assembly
