Only some files show in remote list.
droflig
When I look at remote files alphabetically, I seem to see everything from "A" to half the "P"s. My host's web panel shows all the files and my site is presenting properly.
No problem seeing local files.
Don't see where to make changes in the viewable files.
Re: Only some files show in remote list.
What protocol are you using? How many files can you see? Can you see missing files in any other client using the same protocol? Please attach a full session log file showing the problem (using the latest version of WinSCP).
droflig
May be my server. I tried a different client and it stated "output truncated to 8000 matches."
Remote system = UNIX Type: L8
File transfer protocol = FTP
Compression = No
Can change permissions = Yes
Can change owner/group = No
Can execute arbitrary command = Protocol commands only
Can create symbolic/hard link = No/No
Can lookup user groups = No
Can duplicate remote files = No
Can check available space = No
Can calculate file checksum = No
Native text (ASCII) mode transfers = No
Additional information
The server supports these FTP additional features:
EPRT
IDLE
MDTM
SIZE
MFMT
REST STREAM
MLST type*;size*;sizd*;modify*;UNIX.mode*;UNIX.uid*;UNIX.gid*;unique*;
MLSD
AUTH TLS
PBSZ
PROT
UTF8
TVFS
ESTA
PASV
EPSV
SPSV
ESTP
