FTP unclosable window
Some ssh user
Kraków, Poland
After disconnecting from FTP server sometimes status window appears, but cannot be closed by X, so I have to kill winscp.
Is there any way to close or disable this window at all?
Screen attached
Regards
Description: translated: Disconnected from server
Some ssh user
Quick update: In current version you can actually click inside main window, and connection to any other site is enough to close "status" window. I'll try to reproduce problem on debug version, but currently I have very little time to spear.
Some ssh user
I was using debug version for some time and problem doesn't appear so far. I'm thinking that Polish language can be involved. On debug version there is no option to install and use PL lang.
That's unlikely. It's rather that the debug version being slower won't allow the problem to occur. I'm sending you an email with a development version of WinSCP.
