Problem uploading single file
Dinduch
Maybe i didn't understand the concept of the scripting here, but i have problems with that simple upload of a single file. I have the following script:
open davs://user:password@mac.machine.com/dav/files -rawsettings CacheDirectories=0 CacheDirectoryChanges=0
lcd c:\tmp
put test.txt /
This is just for a simple test and should extended later. The WebDAV Server is at mac.machine.com/dav/files (an not the root path). The file to upload is in c:\tmp and should be uploaded to the root of the webdav (which is mac.machine.com/dav/files/). But all what i get is a 404 (not found) error. I didn't see where my problem is :-(
BTW: I call the script with
"c:\Program Files (x86)\WinSCP\winscp.exe" /log=c:\tmp\script.log /ini=nul /script=c:\tmp\script.txt
Re: Problem uploading single file
Try this (note the added slash in open command and removed slash in put command):
open davs://user:password@mac.machine.com/dav/files/ -rawsettings CacheDirectories=0 CacheDirectoryChanges=0
lcd c:\tmp
put test.txt
If this dos not help, attach a full session log file showing the problem (using the latest version of WinSCP).
Dinduch
Many thx for your help. I have found a solution based on your answer. If i remove the slash for the root remote folder, the upload works as expected.
Now I'm on a other computer where i must use a corporate proxy. But this didn't work. I could successfully authenticate at the proxy, but after something blocked the download. But if i use the WinSCP GUI, i can up-/download all what i want. For now, i must give up to use the script. But maybe I'll try it later again.
Again many thx for your help.
Dinduch
Yes, that's the base, where i started. And yes, the proxy settings where added to the open script, but this didn't help. I'l try it a little more, when i have more time.
