gethostbyname: unknown error April 2018 WIndows 10 update WinSCP portable
PeteGB
United Kingdom
Since running the April 2018 Windows 10 update WinSCP portable no longer connect to my FTP server.
It throws an error saying "gethostbyname: unknown error".
Running the same portable file from a PC that has not been updated works fine, as does running a full version of WinSCP using the same config file.
Re: gethostbyname: unknown error April 2018 WIndows 10 update WinSCP portable
Where do you run the "full version of WinSCP"? On the April 2018 Windows 10 machine or on the other one?
The portable and installed versions are identical. Either you have them configured differently or the portable copy is blocked by Windows firewall or similar.
Can you attach log files from both?
they are using the same .ini config file
Can you attach log files from both?[/quote]
both the .exe file and .com are added to the to firewall exception for public and private networks. other than that I am at a loss
logs attached
Description: log file from successfully connecting updated pc using full version
Description: log file from updated pc trying to connect with portable version
