Print banner in monospace font
Hello.
Please consider printing the authentication banner in a mono-spaced font, so that messages like the following can be displayed correctly:
Thank you so much.
Regards.
+-------------------------------------+-------------------------------------+ | ALERT | ADVERTENCIA | | | | | You are entering into a restricted | Usted esta ingresando a una zona | | area. | restringida. | | This access is restricted to autho- | Este acceso esta restringido a | | rized users only. All activities on | usuarios autorizados exclusivamen- | | this system are logged. | te. Todas las actividades en este | | Unauthorized access will be fully | sistema son registradas. Los acce- | | investigated and reported to the | sos no autorizados seran cabalmente | | appropriate law enforcement agen- | investigados y reportados a las au- | | cies. | toridades de procuracion de jus- | | | ticia competentes. | +-------------------------------------+-------------------------------------+
Thank you so much.
Regards.
