session.GetFiles("path", "path", true) fails to remove remote files
brunis
Using latest 5.13.1 with .NET 4.6.1 and this code does not remove files after fetching:
session.GetFiles(remoteDestinationFolder, receiptFolder, true, transferOptions);
Re: session.GetFiles("path", "path", true) fails to remove remote files
