Issues with Synchronisation & FileMask
Optimaximal
United Kingdom
As part of a SQL Server SSIS package, I'm attempting to download files from an FTPS source using a combination of Powershell and the WinSCP .NET Assembly.
I've used it elsewhere just fine, but I'm having issues making the file mask work correctly with Synchronisation.
The files on the FTP are of a format AA_Unsubscribes_Timestamp.txt, where AA is a collection of letters that could be anything, defined earlier in the SSIS package.
I have the following on a try catch loop in the powershell script:
# Connect to Remote Server, download files and remove
try
   # Connect
   # Set up transfer options
   $transferOptions = New-Object WinSCP.TransferOptions -Property @{
      TransferMode = [WinSCP.TransferMode]::Automatic
      FileMask = "CF_Unsubscribes_*.txt"
   # Synchronize files to local directory, collect results
   $synchronizationResult = $session.SynchronizeDirectories(
      [WinSCP.SynchronizationMode]::Local,
      $localPath,
      $remotePath,
      $False,
      $transferOptions
catch
exit 1
Finally
$session.Dispose()
Unless I'm misreading it, this should only pull down the files beginning with, for example, CF. As it stands, it's pulling down every file, regardless of the mask.
Am I doing something extremely dense?
Edit - The WinSCP Log File attached.
Description: WinSCP Log File
Optimaximal
Ok, further research tells me that using asterisk will collect any files with either the former or latter item.
How do you use EscapeFileMask in the context of directory synchronisation?
Re: Issues with Synchronisation & FileMask
TransferOptions is 7th argument of Session.SynchronizeDirectories method:
https://winscp.net/eng/docs/library_session_synchronizedirectories
      $localPath,
      $remotePath,
      $False,
      $False,
      [WinSCP.SynchronizationCriteria]::Time,
      $transferOptions
See https://winscp.net/eng/docs/faq_library_parameters
