No Error Code if SFTP fails to Connect in Script
DaveR
Hi, I have a simple .cmd script that performs a check for presence of Files and if present calls winscp.com commandline with switches etc..
I have used the if %ERRORLEVEL% neq 0 goto error if a successful connection is used to then trigger a move of files after upload.
However, I had a situation where the SFTP client failed to connect to remote server. The logs showed an error level of 0 upon exit for failing to connect, which then triggered the move function.
Is this expected for a failed connection?
Please advise.
Thanks,
Dave
Re: No Error Code if SFTP fails to Connect in Script
DaveR
Hi Martin,
Apologies for the delay in replying.
I have attached the log file showing a fail to connect and a successful session.
Have also included a copy of the script file.
Thanking you in advance.
Dave
Description: Log File & Script
DaveR
Hi Martin,
After a closer look at my script, I found that I had two syntax errors on the one line so the script worked if there was a successful connection.
After making the corrections, I changed the desitnation IP address to produce a connection timeout. WinSCP now produces the correct errorlevel 1 on a failed connection.
Sorry to have bugged you.
Regards,
Dave
