MissingMethodException in Session.Open error in .NET Core 2.0
Alberto_Valentin
NJ
While running this C# code (.NET Core 2.0.3), the app throws System.MissingMethodException when I get to this line: session.Open(sessionOptions)
Using WinSCP 5.13.1.0
My code:
  Protocol = WinSCP.Protocol.Sftp,
  HostName = "10.22.111.12",
  PortNumber = 22,
  UserName = "ec2-user", // this is on AWS.  linux EC2 instance
  SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:..."
  session.DebugLogPath = @"C:\Projects_c#\AWS\consoleApp\AMFConsoleApp\log.txt";
  session.Open(sessionOptions); // I get the error right here
  session.MoveFile(filePath, "10.22.111.12/appdata/content");
  session.Close();
See the log.txt attached
Description: session.DebugLogPath = @"C:\Projects_c#\AWS\consoleApp\AMFConsoleApp\log.txt";
Re: .net core support
I'll look into it in few days. Once I have anything to test, I'll contact you.
Though note that there's no way to make the assembly working on other system than Windows.
ZielinskiP
Polska
Could you please add me to acess of the developer version of WinSCP ?
I have the same problems with .NET Core 2
Method not found: 'Void System.Threading.EventWaitHandle..ctor(Boolean, System.Threading.EventResetMode, System.String, Boolean ByRef, System.Security.AccessControl.EventWaitHandleSecurity)'.
at WinSCP.ExeSessionProcess.TryCreateEvent(String name, EventWaitHandle& ev)
at WinSCP.ExeSessionProcess.InitializeConsole()
at WinSCP.ExeSessionProcess.Start()
at WinSCP.Session.Open(SessionOptions sessionOptions)
croffers
United States
Downloaded 5.14.1 Beta still getting error
I downloaded the 5.14.1 Beta and I'm still receiving this error:
Was the right version of the dll included in the Beta download?
I'm using .NET Core 2.1
Thanks, Craig
Pathrudu Majji
What is the solution ?
Hi Guys,
Finally what is the solution for this issue. I did not find anything from above discussion.
I had an Azure function which i am hosting in Azure. I installed WinSCP 5.13.8 from NuGet package manager. When I run this code in local, it is working fine. But this throwing above method not found error once I hosted the function and ran it from AZURE.
ERROR: System.MissingMethodException: Method not found: 'Void System.Threading.EventWaitHandle..ctor(Boolean, System.Threading.EventResetMode, System.String, Boolean ByRef, System.Security.AccessControl.EventWaitHandleSecurity)'.
Edit: Sorry for the confusion. It is not working in my local either. Do I need to add any packages? Please help me out.
