Synchronization of many directories with many files
HelmutAden
Deutschland
Hello Mr. Prikryl,
when I start the synchronization of about 1500 directories with max. 1000 files each, WinSCP reads the directories and then it crashes. Is this probably an array limit or a memory limit in then program? I would be happy, if this problem would be solved in the next release.
Kind regards
Helmut Aden
Re: Synchronization of many directories with many files
