Not preserving timestamp
Saul1
Germany
I`m using 5.13 build 8172 GUI mode, W10 64bit and W7 32bit.
When I transfer a file, I noticed that the timestamp of the transfered file was set to the computer timestamp instead of the timestamp of the source file.
This happens with SFTP and WebDav protocol.
It looks like the preserve timestamp setting is ignored.
Is that a bug or wrong adjustment?
Wolfgang
Reply with quote E-mail
Re: Not preserving timestamp
Most WebDAV servers indeed do not support preserving timestamps of uploaded files.
https://winscp.net/eng/docs/ui_transfer_custom#common
But it should work with SFTP. If it does not, please attach a full session log file showing the problem (using the latest version of WinSCP).
Saul1
Germany
attached find the log
  • Cloud-EDFC.log (27.84 KB, Private file)
  • V_Privat_Verschicken_Unbenannt.pdf (159.33 KB, Private file)
SFTP log file please.
You have posted a WebDAV log. I've already explained above that you cannot expect this to work with WebDAV.
