transferoption timestamp remote server ignoring time portion
philmcintosh
NC
I am setting
transferOptions.FileMask = ("*>=" + LastCheckDate.ToString("yyyy-MM-dd:hh:mm:ss"))
but the remote server seems to be ignoring the time portion and sending everything >= just the date portion. Example 2018-04-06:17:09:15 is returning a file with a timestamp of 2018-04-06:05:30:00.
Do I need to format it differently, or is this a problem at the remote end?
Re: transferoption timestamp remote server ignoring time portion
It's possible with some FTP servers.
See "Timestamp precision" section on
https://winscp.net/eng/docs/timestamp#conversion
To confirm, check in WinSCP GUI shows "times" of the affected files in file panel.
If that does not match your scenario, please attach a full session log file showing the problem (using the latest version of WinSCP).
