Directory listing with files show in logs, but not in Explorer or with Session.ListDirectory
cheetah
United States
When I execute the code Session.ListDirectory, the only RemoteDirectoryInfo.File entry I find is .., same shows in the WinSCP GUI. This is an older FTP server, but I can list and see fine even with built-in FTP application in Windows with command prompt.
My same methods and code works fine on 12 or so other FTP servers.
### Below is my output from the logs which shows the directory listing
. 2018-04-02 14:21:30.154 Directory listing successful
. 2018-04-02 14:21:40.481 Getting current directory name.
. 2018-04-02 14:21:40.481 Retrieving directory listing...
> 2018-04-02 14:21:40.482 TYPE A
< 2018-04-02 14:21:40.497 200 Command okay.
> 2018-04-02 14:21:40.508 PASV
< 2018-04-02 14:21:40.512 227 Entering Passive Mode (10,1,1,49,13,161)
> 2018-04-02 14:21:40.512 LIST -a
. 2018-04-02 14:21:40.512 Connecting to 10.1.1.49:3489 ...
< 2018-04-02 14:21:41.821 150 File status okay; about to open data connection.
. 2018-04-02 14:21:41.827 Data connection closed
. 2018-04-02 14:21:41.827 A180402000008AMA                 FIXED    2048 ********
. 2018-04-02 14:21:41.827 R150728070156AMA                 FIXED    2048 ********
. 2018-04-02 14:21:41.827 R150728121066AMA                 FIXED    2048 ********
. 2018-04-02 14:21:41.827 R151127074200AMA                 FIXED    2048 ********
. 2018-04-02 14:21:41.827 R141202092604AMA                 FIXED    2048 ********
. 2018-04-02 14:21:41.827 DIRP_FILESEG                     FIXED    2048 ********
. 2018-04-02 14:21:41.827 P180327065442AMA                 FIXED    2048 ********
< 2018-04-02 14:21:41.961 226 Request successful. Closing data connection.
. 2018-04-02 14:21:41.961 Directory listing successful
. 2018-04-02 14:21:41.961 ..;D;0;1899-12-30T05:00:00.000Z;0;"" [0];"" [0];---------;0
. 2018-04-02 14:22:12.189 Sending dummy command to keep session alive.
> 2018-04-02 14:22:12.189 TYPE A
< 2018-04-02 14:22:12.189 200 Command okay.
Re: Directory listing with files show in logs, but not in Explorer or with Session.ListDirectory
What FTP server is that? What OS?
cheetah
This is a Nortel voice switch, DMS 500, I believe the core OS is UNIX based. Also, I want to say that this listing did work in a previous version of WinSCP, but I am not 100% positive. I tried version 5.7, but that didn't work either.
Thank you for your reply and looking into this for us.
