program crashed when try to edit an image with internal editor
cq674350529
China
After connected to a machine with SSH service running through SFTP protocol, if trying to edit an image in the machine with internal editor directly, the program seems to crash and exits immediately.
Then I repeat the steps above with windbg attached to the WinSCP process, it shows the stack overflow (code 0xc00000fd) exception(not stack buffer overflow exception).
Related information are as follows:
    WinSCP version: 5.13.1(latest version available from the website) (both installed version and portable version have been tested)
    Version of Microsoft Windows: both win10 education version and winxp sp3 have been tested
    Transfer protocol: both SFTP and SCP have beed tested
    User interface: Commander
  • cq@192.168.76.128.log (38.5 KB, Private file)
Description: seesion log
Re: program crashed when try to edit an image with internal editor
cq674350529
Ok, thanks for your reply.
I'll test with the debug version to see if the problem still exists or not.
cq674350529
The problem seems to still exist. I have sent the detailed information to you via email.
By the way, thanks for your great work in WinSCP.
