WinSCP.com get command moslty works, but no content copied.
Allyn
East Peoria, IL
I am using WinSCP.com in a C# Windows application. My target machine is Linux. I am downloading a short (46 bytes) text file using the 'get' command. The get command creates the file correctly on the local PC, but its size is 0 - i.e. no content. I am looking for ideas on may be the cause of this defect?
Re: WinSCP.com get command moslty works, but no content copied.
Also consider using .NET assembly, instead of driving a console application:
https://winscp.net/eng/docs/library
