Upload file fails when account has no LIST permission
menezesj
United States
I have been encountering an issue with WINSCP since our provider has changed their FTP server to no longer allow LIST for our accounts. I have tried with both WinSCP.com and WinSCP GUI, and run into issues.
Error Messages:
(GUI)
Error
Error listing directory '/'.
Access is denied.
OK   Help
Through an interactive command line, I get the error, but am allowed to retry which will usually work within the next 3 retries.:
winscp> put e:\ftpfiles\VendorName\sw_user_import.csv sw_user_import.csv
e:\...\sw_user_import.csv |          16 KB |  205.1 KB/s | binary |   9%
Error transferring file 'e:\ftpfiles\VendorName\sw_user_import.csv'.
Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-
RSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA384
The specified network name is no longer available.
(A)bort, (R)etry, (S)kip, Ski(p) all: Retry
e:\...\sw_user_import.csv |          16 KB |  114.3 KB/s | binary |   9%
Access is denied.
e:\...\sw_user_import.csv |         169 KB |   93.8 KB/s | binary | 100%
winscp> exit
When running through a script, it fails automatically:
c:\Program Files (x86)\WinSCP>winscp.com /script=E:\ftpfiles\VendorName\SWFTP.txt
Connecting to swaftp1.VendorName.com ...
TLS connection established. Waiting for welcome message...
Connected
Starting the session...
Session started.
Active session: [1] UserNameABC@swaftp1.VendorName.com
batch           continue
e:\...\sw_user_import.csv |            0 B |    0.0 KB/s | binary |   0%
(A)bort, (R)etry, (S)kip, Ski(p) all: Skip
When I upload using a different client (FileZilla) using the same account, credentials and file, I am able to upload the file successfully (although it does complain about not being able to LIST)
Here is a detailed log from WinSCP:
. 2018-03-15 11:03:15.060 --------------------------------------------------------------------------
. 2018-03-15 11:03:15.060 WinSCP Version 5.13 (Build 8172) (OS 6.3.9600 - Windows Server 2012 R2 Standard)
. 2018-03-15 11:03:15.060 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2018-03-15 11:03:15.060 Log level: Normal, Logging passwords
. 2018-03-15 11:03:15.060 Local account: CVUSD\MyUser
. 2018-03-15 11:03:15.060 Working directory: c:\Program Files (x86)\WinSCP
. 2018-03-15 11:03:15.060 Process ID: 4916
. 2018-03-15 11:03:15.060 Command-line: "c:\Program Files (x86)\WinSCP\WinSCP.exe" /console=5.13.0 /consoleinstance=_6328_55 "/log=e:\ftpfiles\VendorName\log.txt" "/loglevel=*"
. 2018-03-15 11:03:15.060 Time zone: Current: GMT-7, Standard: GMT-8 (Pacific Standard Time), DST: GMT-7 (Pacific Daylight Time), DST Start: 3/11/2018, DST End: 11/4/2018
. 2018-03-15 11:03:15.060 Login time: Thursday, March 15, 2018 11:03:15 AM
. 2018-03-15 11:03:15.060 Script: Retrospectively logging previous script records:
> 2018-03-15 11:03:15.060 Script: open ftps://UserNameABC:Pass123@swaftp1.VendorName.com:21/ -explicit
. 2018-03-15 11:03:15.060 Session name: UserNameABC@swaftp1.VendorName.com (Ad-Hoc site)
. 2018-03-15 11:03:15.060 Host name: swaftp1.VendorName.com (Port: 21)
. 2018-03-15 11:03:15.060 User name: UserNameABC (Password: Pass123, Key file: No, Passphrase: No)
. 2018-03-15 11:03:15.060 Transfer Protocol: FTP
. 2018-03-15 11:03:15.060 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2018-03-15 11:03:15.060 Disable Nagle: No
. 2018-03-15 11:03:15.060 Proxy: None
. 2018-03-15 11:03:15.060 Send buffer: 262144
. 2018-03-15 11:03:15.060 UTF: Auto
. 2018-03-15 11:03:15.060 FTPS: Explicit TLS/SSL [Client certificate: No]
. 2018-03-15 11:03:15.060 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2018-03-15 11:03:15.060 Session reuse: Yes
. 2018-03-15 11:03:15.060 TLS/SSL versions: TLSv1.0-TLSv1.2
. 2018-03-15 11:03:15.060 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2018-03-15 11:03:15.060 Cache directory changes: Yes, Permanent: Yes
. 2018-03-15 11:03:15.060 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2018-03-15 11:03:15.060 Timezone offset: 0h 0m
. 2018-03-15 11:03:15.061 Connecting to swaftp1.VendorName.com ...
. 2018-03-15 11:03:15.065 Connected with swaftp1.VendorName.com, negotiating TLS connection...
< 2018-03-15 11:03:15.211 220 Microsoft FTP Service
> 2018-03-15 11:03:15.211 AUTH TLS
< 2018-03-15 11:03:15.284 234 AUTH command ok. Expecting TLS Negotiation.
. 2018-03-15 11:03:15.557 Verifying certificate for "VendorName, Inc." with fingerprint 9b:47:ac:eb:4f:c2:a6:91:ea:f6:f3:51:39:1d:e0:5c:72:f1:25:cb and 20 failures
. 2018-03-15 11:03:15.557 Certificate common name "*.VendorName.com" matches hostname
. 2018-03-15 11:03:15.590 Certificate verified against Windows certificate store
. 2018-03-15 11:03:15.591 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA384
. 2018-03-15 11:03:15.591 TLS connection established. Waiting for welcome message...
> 2018-03-15 11:03:15.591 USER UserNameABC
< 2018-03-15 11:03:15.664 331 Password required
> 2018-03-15 11:03:15.664 PASS Pass123
< 2018-03-15 11:03:15.737 230 User logged in.
> 2018-03-15 11:03:15.737 SYST
. 2018-03-15 11:03:15.810 The server is probably running Windows, assuming that directory listing timestamps are affected by DST.
< 2018-03-15 11:03:15.810 215 Windows_NT
> 2018-03-15 11:03:15.810 FEAT
< 2018-03-15 11:03:15.883 211-Extended features supported:
< 2018-03-15 11:03:15.884  LANG EN*
< 2018-03-15 11:03:15.884  UTF8
< 2018-03-15 11:03:15.884  AUTH TLS;TLS-C;SSL;TLS-P;
< 2018-03-15 11:03:15.884  PBSZ
< 2018-03-15 11:03:15.884  PROT C;P;
< 2018-03-15 11:03:15.884  CCC
< 2018-03-15 11:03:15.884  HOST
< 2018-03-15 11:03:15.884  SIZE
< 2018-03-15 11:03:15.885  MDTM
< 2018-03-15 11:03:15.885  REST STREAM
< 2018-03-15 11:03:15.885 211 END
> 2018-03-15 11:03:15.885 OPTS UTF8 ON
< 2018-03-15 11:03:15.958 200 OPTS UTF8 command successful - UTF8 encoding now ON.
> 2018-03-15 11:03:15.958 PBSZ 0
< 2018-03-15 11:03:16.031 200 PBSZ command successful.
> 2018-03-15 11:03:16.031 PROT P
< 2018-03-15 11:03:16.104 200 PROT command successful.
. 2018-03-15 11:03:16.105 Connected
. 2018-03-15 11:03:16.105 --------------------------------------------------------------------------
. 2018-03-15 11:03:16.105 Using FTP protocol.
. 2018-03-15 11:03:16.105 Doing startup conversation with host.
> 2018-03-15 11:03:16.105 PWD
< 2018-03-15 11:03:16.178 257 "/" is current directory.
. 2018-03-15 11:03:16.178 Getting current directory name.
. 2018-03-15 11:03:16.178 Startup conversation with host finished.
< 2018-03-15 11:03:16.179 Script: Active session: [1] UserNameABC@swaftp1.VendorName.com
> 2018-03-15 11:03:20.308 Script: put e:\ftpfiles\VendorName\sw_user_import.csv
. 2018-03-15 11:03:20.309 Copying 1 files/directories to remote directory "/" - total size: 173,989
. 2018-03-15 11:03:20.309   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2018-03-15 11:03:20.309   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: ; ResumeL: 0
. 2018-03-15 11:03:20.309   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2018-03-15 11:03:20.309 Retrieving listing to detect timezone difference
. 2018-03-15 11:03:20.309 Retrieving directory listing...
> 2018-03-15 11:03:20.310 TYPE A
< 2018-03-15 11:03:20.383 200 Type set to A.
> 2018-03-15 11:03:20.383 PASV
< 2018-03-15 11:03:20.457 227 Entering Passive Mode (52,206,191,229,214,216).
> 2018-03-15 11:03:20.457 LIST
. 2018-03-15 11:03:20.457 Connecting to 52.206.191.229:55000 ...
. 2018-03-15 11:03:20.602 Data connection closed
. 2018-03-15 11:03:20.603 <Empty directory listing>
< 2018-03-15 11:03:20.603 550 Access is denied.
. 2018-03-15 11:03:20.603 Could not retrieve directory listing
. 2018-03-15 11:03:20.603 File: 'e:\ftpfiles\VendorName\sw_user_import.csv' [2018-03-15T06:50:01.264Z] [173989]
. 2018-03-15 11:03:20.604 Copying "e:\ftpfiles\VendorName\sw_user_import.csv" to remote directory started.
. 2018-03-15 11:03:20.604 Binary transfer mode selected.
. 2018-03-15 11:03:20.604 Starting upload of e:\ftpfiles\VendorName\sw_user_import.csv
> 2018-03-15 11:03:20.604 TYPE A
< 2018-03-15 11:03:20.677 200 Type set to A.
> 2018-03-15 11:03:20.677 PASV
< 2018-03-15 11:03:20.750 227 Entering Passive Mode (52,206,191,229,214,223).
> 2018-03-15 11:03:20.750 LIST
. 2018-03-15 11:03:20.750 Connecting to 52.206.191.229:55007 ...
. 2018-03-15 11:03:20.822 Data connection closed
. 2018-03-15 11:03:20.822 <Empty directory listing>
< 2018-03-15 11:03:20.823 550 Access is denied.
> 2018-03-15 11:03:20.823 SIZE sw_user_import.csv
< 2018-03-15 11:03:20.896 550 Access is denied.
> 2018-03-15 11:03:20.896 MDTM sw_user_import.csv
< 2018-03-15 11:03:20.970 213 20180315065001
> 2018-03-15 11:03:20.970 TYPE I
< 2018-03-15 11:03:21.043 200 Type set to I.
> 2018-03-15 11:03:21.043 PASV
< 2018-03-15 11:03:21.116 227 Entering Passive Mode (52,206,191,229,214,220).
> 2018-03-15 11:03:21.116 STOR sw_user_import.csv
. 2018-03-15 11:03:21.116 Connecting to 52.206.191.229:55004 ...
< 2018-03-15 11:03:21.190 150 Opening BINARY mode data connection.
. 2018-03-15 11:03:21.262 Session ID reused
. 2018-03-15 11:03:21.263 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA384
. 2018-03-15 11:03:21.263 TLS connection established
. 2018-03-15 11:03:21.263 Data connection closed
< 2018-03-15 11:03:21.336 550 The specified network name is no longer available.
. 2018-03-15 11:03:21.336 Copying files to remote side failed.
* 2018-03-15 11:03:21.336 (ExtException) **Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA384
* 2018-03-15 11:03:21.336 **
* 2018-03-15 11:03:21.336 Copying files to remote side failed.
* 2018-03-15 11:03:21.336 The specified network name is no longer available.
. 2018-03-15 11:03:21.336 Asking user:
. 2018-03-15 11:03:21.336 Error transferring file 'e:\ftpfiles\VendorName\sw_user_import.csv'. ("Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA384
. 2018-03-15 11:03:21.336 ","Copying files to remote side failed.","The specified network name is no longer available. ")
< 2018-03-15 11:03:21.336 Script: Error transferring file 'e:\ftpfiles\VendorName\sw_user_import.csv'.
< 2018-03-15 11:03:21.336 Script: Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA384
< 2018-03-15 11:03:21.336 Copying files to remote side failed.
< 2018-03-15 11:03:21.336 The specified network name is no longer available.
. 2018-03-15 11:03:23.532 Starting upload of e:\ftpfiles\VendorName\sw_user_import.csv
> 2018-03-15 11:03:23.532 TYPE A
< 2018-03-15 11:03:23.605 200 Type set to A.
> 2018-03-15 11:03:23.605 PASV
< 2018-03-15 11:03:23.678 227 Entering Passive Mode (52,206,191,229,214,224).
> 2018-03-15 11:03:23.678 LIST
. 2018-03-15 11:03:23.678 Connecting to 52.206.191.229:55008 ...
. 2018-03-15 11:03:23.749 Data connection closed
. 2018-03-15 11:03:23.750 <Empty directory listing>
< 2018-03-15 11:03:23.751 550 Access is denied.
> 2018-03-15 11:03:23.751 SIZE sw_user_import.csv
< 2018-03-15 11:03:23.824 550 Access is denied.
> 2018-03-15 11:03:23.824 MDTM sw_user_import.csv
< 2018-03-15 11:03:23.897 550 The system cannot find the file specified.
> 2018-03-15 11:03:23.898 TYPE I
< 2018-03-15 11:03:23.970 200 Type set to I.
> 2018-03-15 11:03:23.971 PASV
< 2018-03-15 11:03:24.043 227 Entering Passive Mode (52,206,191,229,214,219).
> 2018-03-15 11:03:24.044 STOR sw_user_import.csv
. 2018-03-15 11:03:24.044 Connecting to 52.206.191.229:55003 ...
< 2018-03-15 11:03:24.117 150 Opening BINARY mode data connection.
. 2018-03-15 11:03:24.276 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-SHA384, 2048 bit RSA, ECDHE-RSA-AES256-SHA384 TLSv1.2 Kx=ECDH     Au=RSA  Enc=AES(256)  Mac=SHA384
. 2018-03-15 11:03:24.276 TLS connection established
< 2018-03-15 11:03:24.861 226 Transfer complete.
> 2018-03-15 11:03:24.861 MDTM 20180315065001 sw_user_import.csv
< 2018-03-15 11:03:24.934 213 20180315065001
. 2018-03-15 11:03:24.934 Upload successful
. 2018-03-15 11:03:24.934 Transfer done: 'e:\ftpfiles\VendorName\sw_user_import.csv' => '/sw_user_import.csv' [173989]
. 2018-03-15 11:03:24.934 Copying finished: Transferred: 173,989, Elapsed: 0:00:04, CPS: 111,388/s
> 2018-03-15 11:03:35.542 Script: exit
. 2018-03-15 11:03:35.542 Script: Exit code: 0
. 2018-03-15 11:03:35.545 Disconnected from server
And the comparable log from FileZilla:
Status:   Resolving address of swaftp1.VendorName.com
Status:   Connecting to 52.206.191.229:21...
Status:   Connection established, waiting for welcome message...
Response:   220 Microsoft FTP Service
Command:   AUTH TLS
Response:   234 AUTH command ok. Expecting TLS Negotiation.
Status:   Initializing TLS...
Status:   Verifying certificate...
Status:   TLS connection established.
Command:   USER CA01902277
Response:   331 Password required
Command:   PASS ****************
Response:   230 User logged in.
Command:   OPTS UTF8 ON
Response:   200 OPTS UTF8 command successful - UTF8 encoding now ON.
Command:   PBSZ 0
Response:   200 PBSZ command successful.
Command:   PROT P
Response:   200 PROT command successful.
Status:   Logged in
Status:   Starting upload of E:\FTPFiles\VendorName\sw_user_import.csv
Command:   CWD /
Response:   250 CWD command successful.
Command:   PWD
Response:   257 "/" is current directory.
Status:   Retrieving directory listing of "/"...
Command:   TYPE I
Response:   200 Type set to I.
Command:   PASV
Response:   227 Entering Passive Mode (52,206,191,229,214,221).
Command:   LIST
Response:   550 Access is denied.
Command:   SIZE sw_user_import.csv
Command:   PASV
Response:   227 Entering Passive Mode (52,206,191,229,214,216).
Command:   STOR sw_user_import.csv
Response:   150 Opening BINARY mode data connection.
Response:   226 Transfer complete.
Status:   File transfer successful, transferred 173,989 bytes in 1 second
Command:   PASV
Response:   227 Entering Passive Mode (52,206,191,229,214,223).
Command:   LIST
Error:   Failed to retrieve directory listing
Is there a set of options I can use to work around this issue, and have WinSCP consistently work (especially via a script)?
Thank you,
Joel
Re: Upload file fails when account has no LIST permission
I have no idea what does the server mean by "The specified network name is no longer available."
Nor I see any relation of your upload problem to the "no LIST permission".
Did you consult this with the server administrator? Is there anything useful in the FTP server log file?
