WinSCP freezes after 30 seconds or more
andrbazz
Italy
Hi guys,
almost every time i try to do anything, after 30 seconds whatever action i try to do (click on buttons or anything else), the app freezes and i have to force the shut down because it does not respond anymore. If i don't do anything, the connection remain active and the app doesn't freeze. I tried hundreds of times and sometimes, but i don't kwon why, it does not freeze and i can use it without problem.
Protocol: WebDAV
Version: 5.11.3 (Build 7995)
I'm attaching the log.
Thanks anybody in advance for support.
Andrea
Re: WinSCP freezes after 30 seconds or more
Demetrio
The same for me
It's the same for me. The issue started for me a long time ago. I already tried to update, to make a clean install (deleting cfg files) and so on. Nothing to do, It looks like there's something "external" that breaks winscp.
It doesn't depend from what I'm doing, sometime it freezes a few second after login, once it stopped working before login.
Re: The same for me
The same answer from me: Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
matovu_isaac
WINSCP FREEZES
OMG god this has been killing me. i have to keep redoing everything because winscp chooses to just freeze every now and again,
Re: WINSCP FREEZES
The same answer: Can you send me an email, so I can send you back a debug version of WinSCP to track the problem? Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
Mercy wrote:
It´s freeeezing... all new verions.
Re: 5.13.8 keeps freezing
fippy wrote:
Keeps freezing intermittently - only way to kill it is with windows task manager..!
natalie87684
I am also having this issue. WinSCP freezes when I try to move between folders and when transferring/downloading files loses connection midway. sometimes, it logs out and back in, but doesn't restart the transfer
hec
ditto
and me too...
anybody got any workable solution (or alternative)?!?!
I note that I can cd either local or remote without any freeze BUT as soon as I try and drag from remote to local it goes 'not responding'
Re: ditto
hec wrote:
and me too...
And the same answer:
