S3 feature doesn't work with MinIO server
mattn
mattn avatar
Japan
Minio is an object storage server that compatible with Amazon S3. But, since WinSCP seems look {bucket}+hostname, it doesn't work on MinIO server. Do you have plan to support S3 compatible servers?
Re: s3 feature doesn't work with minio server
mattn
mattn avatar
Japan
Sorry, It will be in later since my MinIO server works on my office. I will take few days to take the logs. But you can understand why this occurred. See S3FileSystem.cpp:491
Result.uriStyle = S3UriStyleVirtualHost;
For S3 compatible servers, uriStyle should be S3UriStylePath.
Gianni
Italy
Also, MinIO generates a URL like http://127.0.0.1:9000
If you select S3 and paste this URL, WinSCP switches to WebDAV automatically.
Gianni
Italy
I've uploaded a log session. Note that it tries to connect to port 443 instead of 9000 because it forces https
  • s3.log (8.58 KB, Private file)
Description: log session
Thanks for the information. I've set up MinIO server myself, so I can now reproduce the problem.
I'll see if more people ask for support of MinIO server.
Re: Force SSL
@axer: Sorry, I do not understand the purpose of your post. Are you asking how to connect with S3 to a server that does not support TLS/SSL?
iany
Re: Force SSL
Hi Martin, I have the same problem. We need a way to connect to a S3 compatible server without TLS.. I have a private S3 object server using MinIO (but could be any other S3 compatible).. When configuring a new S3 "Amazon S3" protocol in WinSCP we can't disable TLS/SSL (in Advanced we can only set the minimum version) .. and if we put in host name something like http://example.com/ it switches to WebDAV.. Can you please take a look into it? Thank you :)
