Create WinSCP.SessionOptions takes 20 seconds in COM and account not logged on
abnew1
Italy
I use WinSCPnet.dll with a program written with AutoIT script language. It acts as a COM.
It works fine but when I start the program from a scheduled task (under Windows Server 2012 R2) using an user account that is not logged on, it takes 20 seconds for the WinSCP.SessionOptions create object. If I run the scheduled task with a user already logged on, it create the object immediately.
So, I tried with two simple scripts, one with Powershell and one with VBScript.
With Powershell there is no wait time and with VBScript it takes 20 seconds too.
This is the Powershell code:
try
    # Load WinSCP .NET assembly
    # Setup session options
    Write-Host $(Get-Date -format "dd/MM/yyyy HH:mm:ss") " Create object WinSCP.SessionOptions`r"
        HostName = "***.**.***.**"
        UserName = "AldoProva"
        Password = "***"
        SshHostKeyFingerprint = "ssh-rsa 2048 ***"
    Write-Host $(Get-Date -format "dd/MM/yyyy HH:mm:ss") " Object created`r"
    Write-Host $(Get-Date -format "dd/MM/yyyy HH:mm:ss") " Create object WinSCP.Session`r"
    try
        # Connect
        Write-Host $(Get-Date -format "dd/MM/yyyy HH:mm:ss") " Open Session`r"
        Write-Host $(Get-Date -format "dd/MM/yyyy HH:mm:ss") " Session opened`r"
        # Upload files
        Write-Host $(Get-Date -format "dd/MM/yyyy HH:mm:ss") " Create object WinSCP.TransferOptions`r"
        $transferResult =
            $session.PutFiles("E:\test.txt", "/", $False, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
            Write-Host $(Get-Date -format "dd/MM/yyyy HH:mm:ss") " Upload of $($transfer.FileName) succeeded`r"
    finally
        # Disconnect, clean up
        $session.Dispose()
    Write-Host "`r"
    exit 0
catch
    exit 1
This is the result... started with "powershell -file E:\Aldo\testps.ps1 >>E:\Aldo\testps.log" command.
First session with an account logged on (speedy), second session with an account not logged on (speedy).
21/02/2018 17:01:05  Create object WinSCP.SessionOptions
21/02/2018 17:01:05  Object created
21/02/2018 17:01:05  Open Session
21/02/2018 17:01:07  Session opened
21/02/2018 17:01:07  Create object WinSCP.TransferOptions
21/02/2018 17:01:07  Object created
21/02/2018 17:01:07  Upload of E:\test.txt succeeded
21/02/2018 17:01:32  Create object WinSCP.SessionOptions
21/02/2018 17:01:32  Object created
21/02/2018 17:01:33  Object created
21/02/2018 17:01:33  Open Session
21/02/2018 17:01:35  Session opened
21/02/2018 17:01:35  Create object WinSCP.TransferOptions
21/02/2018 17:01:35  Object created
21/02/2018 17:01:35  Upload of E:\test.txt succeeded
This is the VBScript code:
Option Explicit
' Setup session options
Dim sessionOptions
WScript.Echo Date & " " & Time & " Create object WinSCP.SessionOptions"
Set sessionOptions = WScript.CreateObject("WinSCP.SessionOptions")
WScript.Echo Date & " " & Time & " Object created"
With sessionOptions
    .Protocol = 0
    .HostName = "***.**.***.**"
    .UserName = "AldoProva"
    .Password = "***"
    .SshHostKeyFingerprint = "ssh-rsa 2048 ***"
End With
Dim session
WScript.Echo Date & " " & Time & " Create object WinSCP.Session"
Set session = WScript.CreateObject("WinSCP.Session")
' Connect
WScript.Echo Date & " " & Time & " Open session"
session.Open sessionOptions
WScript.Echo Date & " " & Time & " Session opened"
' Upload files
Dim transferOptions
WScript.Echo Date & " " & Time & " Create object WinSCP.TransferOptions"
Set transferOptions = WScript.CreateObject("WinSCP.TransferOptions")
transferOptions.TransferMode = 0
Dim transferResult
Set transferResult = session.PutFiles("E:\test.txt", "/", False, transferOptions)
' Throw on any error
' Print results
Dim transfer
For Each transfer In transferResult.Transfers
    WScript.Echo Date & " " & Time & " Upload of " & transfer.FileName & " succeeded"
Next
' Disconnect, clean up
session.Dispose
WScript.Echo ""
This is the result... started with "cscript E:\Aldo\testvbs.vbs >>E:\Aldo\testvbs.log" command.
First session with an account logged on (speedy), second session with an account not logged on (20 seconds).
Microsoft (R) Windows Script Host Version 5.8
Copyright (C) Microsoft Corporation. All rights reserved.
21/02/2018 17:01:07 Create object WinSCP.SessionOptions
21/02/2018 17:01:08 Object created
21/02/2018 17:01:09 Create object WinSCP.Session
21/02/2018 17:01:09 Object created
21/02/2018 17:01:09 Open session
21/02/2018 17:01:11 Session opened
21/02/2018 17:01:11 Create object WinSCP.TransferOptions
21/02/2018 17:01:11 Object created
21/02/2018 17:01:11 Upload of E:\test.txt succeeded
21/02/2018 17:01:35 Create object WinSCP.SessionOptions
21/02/2018 17:01:55 Object created
21/02/2018 17:01:55 Create object WinSCP.Session
21/02/2018 17:01:55 Open session
21/02/2018 17:01:57 Session opened
21/02/2018 17:01:57 Create object WinSCP.TransferOptions
21/02/2018 17:01:57 Object created
21/02/2018 17:01:57 Upload of E:\test.txt succeeded
Do you have ideas on how to avoid these 20 seconds wait in COM using?
I tried with WinSCP 5.9.4, 5.11.3 and the last 5.13. Always the same result.
Grazie. Ciao,
Aldo
Re: Create WinSCP.SessionOptions takes 20 seconds in COM and account not logged on
Sorry, I do not know.
But the delay most probably happens even before the assembly is loaded.
