WinSCP doesn't show waiting & completed files in queue
kludev@...
I noticed that when I upload multiple items. The queue only shows the files being actively transferred. It doesn't show the "Waiting" files nor the completed files.
I'm not sure if it's a bug. But it seems inconsistent with the description in the doc, where both waiting and completed items are shown in the queue list. I don't find a settings for this either.
I'm using version 5.11.3. Protocol is SFTP.
Screenshot is attached.
Re: WinSCP doesn't show waiting & completed files in queue
WinSCP transfer queue list shows transfer operations/batches, not individual files.
You can schedule multiple operation/batches. If you schedule too many of them, you will get the "Waiting" lines, that you see in the documentation.
So it's not a bug, it's a feature.
Jey
France
Unfortunately, this feature doesn't answer to everyone.
I found many other persons on internet who would like to have the full list of waiting files transfers (like in FileZilla). But it's not available :'(
Tobey
Important
i was also looking to find how to view the files.
I do filter "modified" files, and would NEED to know what files these are, thus need to see all single files for checking if everything is fine.
I guess it shouldnt be too much difficulty to hava a treeview just like in an explorer.
I really got stuck at a task currently, and changed from totalcommander to winscp, and i really liked, that you could filter for modfied files. But uploading an amount of unknown files is just something i would rarely do, so this filter feature becomes useless for me actually.
If i would have the money i would have gave you a little incentive. The only currency i could pay with is time.
Re: Important
@starx: If you follow the link, you will see that the feature is implemented since 5.18 (November 2020). FTPS is supported for over a decade (4.2, February 2009).
