Enabling the UFW Firewall in Ubuntu causes WinSCP to not display hidden folders/files
RudieStoltz
South Afrca
Good Day, I need help please.
I have disabled most incoming connections except for SSH,443,21.I also enabled all outgoing connections/ports.
I then enabled the UFW firewall in Ubuntu.
When I use WinSCP now, it does not shows any hidden folders, previously it did show hidden folders and files. Is there a port etc that I must open for it to work ?
Thank you
Re: Enabling the UFW Firewall in Ubuntu causes WinSCP to not display hidden folders/files
What protocol are you using with WinSCP? Please attach a full session log file showing the problem (using the latest version of WinSCP). Do you have a log file from times, when WinSCP was showing the hidden files? Or can you reproduce that (by temporarily reverting your server configuration)?
